Reuse GBIC
Dear Sir,
I have GBIC for WS-X6416-GBIC (on 6506) and now I am replacing the 6506 with 4506E. WS-X4418-GB will be used this time.
Can I use the old GBIC on WS-X6416-GBIC?
1 REPLY
Hall of Fame Super Blue
Re: Reuse GBIC
Hi Joseph
You don't say which GBIC it is.
The WS-X4418-GB supports the following GBIC's
WS-G5484, G5486, G5487
The WS-X6416-GBIC supports
WS-G5483, WS-G5484, G5486, G5487
The WS-G5483 is a for Cat5 so unless you are using that in your 6416 module you should be fine.
Attached is the full matrix for GBIC compatability between Catalyst switches.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Jon
115
