Rip V2 Loopback Advertisement
Hi, I am having some difficulty understanding a setback I'm experiencing with RIP version 2 advertising and a loopback design.
I have 3 routers, each connected through ethernet and serial, and each with a loopback interface using a /29 mask and the ips 10.1.1.1-3. I have added the networks to my router rip satements, networks 192.168.1.0 and 10.1.1.0. All of my ethernet and serial interafces using the 192.168.1.0 spaces are able to ping fine to and from each router.
The problem I can't understand at the moment is in my router rip statement: it is changing 10.1.1.0 to 10.0.0.0. I thought at first this was because I wasn't using the no auto-summarization statement, but i have added that and it is still changing the network back to 10.0.0.0. I know this is something simple that I am just overlooking in my notes, but I need help. Hints, suggestions and full-on answers are all welcome!
here is a spoke router ip route:
Gateway of last resort is not set
     10.0.0.0/29 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, Loopback0
     192.168.1.0/24 is variably subnetted, 3 subnets, 3 masks
C       192.168.1.8/29 is directly connected, Serial1/3
C       192.168.1.0/30 is directly connected, FastEthernet0/0
R       192.168.1.128/25 [120/1] via 192.168.1.1, 00:00:20, FastEthernet0/0
                         [120/1] via 192.168.1.10, 00:00:25, Serial1/3
R2#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
and here is a show run of that router:
R2#show run
Building configuration...
Current configuration : 1041 bytes
version 12.3
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$0UdW$yy6AD7sKOwdA1EYZPGp0A0
enable password lab
memory-size iomem 30
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
no ip cef
interface Loopback0
ip address 10.1.1.2 255.255.255.248
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.252
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
ip address 192.168.1.12 255.255.255.248
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip http server
no ip http secure-server
ip classless
line con 0
login
line aux 0
line vty 0 4
password lab
login
line vty 5 181
password lab
login
end
Look, you are using 10.1.1.1 - 10.1.1.2 - 10.1.1.3 / 29 for your loopbacks, they are basically in ONE logical subent, and this is where u r getting it wrong. all ur routers think they have these routes Connected, so adv's are getting ignored.
10.1.1.0 - 10.1.1.7 is practically ONE range try ip addresses in another ranges for each Lo0 or use an /32 mask for them.
HTH,
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
6 Replies 6
John Blakley
RIP always changes the entry to the classful network. Since you have version 2 specified, it will advertise the mask along with your subnets, so what you're seeing is normal. As far as not having your other networks, make sure that you have version 2 specified in the rip process on those routers as well along with no auto-summary. Can you post the other rip processes if this doesn't work?
HTH, John *** Please rate all useful posts ***
It looks like version 2 is enabled on all the routers, and I can ping on the 192 adresses, just not the 10s.
here are the running configs and ip routes for all three routers:
router 1:
hostname R1
interface Loopback0
ip address 10.1.1.1 255.255.255.248
interface Ethernet0
ip address 192.168.1.130 255.255.255.128
interface Serial0
ip address 192.168.1.9 255.255.255.248
clockrate 64000
interface Serial1
ip address 192.168.1.10 255.255.255.248
clockrate 64000
router rip
version 2
network 192.168.1.0
network 10.0.0.0
no auto-summary
ip classless
end
                       is directly connected, Serial0
R       192.168.1.0/30 [120/1] via 192.168.1.129, 00:00:17, Ethernet0
                       [120/1] via 192.168.1.11, 00:00:24, Serial0
                       [120/1] via 192.168.1.12, 00:00:14, Serial1
C       192.168.1.128/25 is directly connected, Ethernet0
R1#ping 10.1.1.2
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
R1#ping 10.1.1.3
Sending 5, 100-byte ICMP Echos to 10.1.1.3, timeout is 2 seconds:
Router 2:
hostname R2
ip subnet-zero
no ip cef
interface Loopback0
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip http server
ip classless
end
R       192.168.1.128/25 [120/1] via 192.168.1.1, 00:00:18, FastEthernet0/0
R2#ping 10.1.1.1
R2#ping 10.1.1.3
Router 3:
hostname R3
no aaa new-model
ip subnet-zero
ip cef
interface Loopback0
ip address 10.1.1.3 255.255.255.248
ip address 192.168.1.129 255.255.255.128
duplex auto
speed auto
interface Serial0/0
ip address 192.168.1.11 255.255.255.248
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
no ip http server
ip classless
end
C       192.168.1.8/29 is directly connected, Serial0/0
C       192.168.1.0/30 is directly connected, FastEthernet0/1
C       192.168.1.128/25 is directly connected, FastEthernet0/0
R3#ping 10.1.1.1
R3#ping 10.1.1.2
And just for kicks here are some ping examples over the serial connection that are working:
R3#ping 192.168.1.9
Sending 5, 100-byte ICMP Echos to 192.168.1.9, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/50/64 ms
R3#ping 192.168.1.10
Sending 5, 100-byte ICMP Echos to 192.168.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/56/84 ms
R3#ping 192.168.1.12
Sending 5, 100-byte ICMP Echos to 192.168.1.12, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/66/80 ms
smehrnia
Level 7
Level 7
Hey john,
by default rip only sends ver 1 updates, but is open to receive ver 1 and 2. so you have to manually make it send out ver 2 updates.
to make it all ver 2, add these commands under your interfaces involved in rip process:
ip rip send ver 2
ip rip receive ver 2
HTH,
Soroush.
Hope it Helps!
Soroush.
I have added those statements and still cannot ping.
I ran a debug ip rip on R1 and found that the advertisements are being sent across my serial connections. Both are directly connected, but I am not receiving any advertisements from the othe loopbacks. I am however ignoring the advertisement for the loopback on R1. It is sending and receiving in version 2.
Routers 2 and 3 which are spokes from R1 are not sending or receiving any RIP updates. I am getting the sneaking suspicion that this has everything to do with my serial hub and spoke setup. I have not configured encapsulation or any of that. Since I don't have PPP setup, I'm guessing the RIP advertisements are being dropped and routers 2 and 3 simply have nothing to advertise to or receiv from.
Thanks again for all the input!
Also, here is a debug from R1
R1#
RIP: sending v2 update to 224.0.0.9 via Ethernet0 (192.168.1.130)
     192.168.1.8/29 -> 0.0.0.0, metric 1, tag 0
     10.1.1.0/29 -> 0.0.0.0, metric 1, tag 0
RIP: sending v2 update to 224.0.0.9 via Loopback0 (10.1.1.1)
     192.168.1.0/30 -> 0.0.0.0, metric 2, tag 0
     192.168.1.128/25 -> 0.0.0.0, metric 1, tag 0
RIP: sending v2 update to 224.0.0.9 via Serial0 (192.168.1.9)
RIP: sending v2 update to 224.0.0.9 via Serial1 (192.168.1.10)
RIP: ignored v2 packet from 10.1.1.1 (sourced from one of our addresses)
RIP: received v2 update from 192.168.1.129 on Ethernet0
     10.1.1.0/29 -> 0.0.0.0 in 1 hops
     192.168.1.0/30 -> 0.0.0.0 in 1 hops
     192.168.1.8/29 -> 0.0.0.0 in 1 hops
RIP: received v2 update from 192.168.1.11 on Serial0
     192.168.1.128/25 -> 0.0.0.0 in 1 hops
RIP: received v2 update from 192.168.1.12 on Serial1
     192.168.1.128/25 -> 0.0.0.0 in 1 hopsunebug all
HTH,
Soroush.
Hope it Helps!
Soroush.
Soroushm,
Thank you for that lesson. I misunderstood the concept of discontiguous networks. I thought that in addition to subnets of same network number being able to be connected by subnets of different networknumbers, directly connected routers could all belong to the same network as incremented hosts. Obviously this was wrong.
I changed each loopback to a /32 and I can ping every interface from ever other interace now.
