Community Member
RMON - for routers only?
Is RMON for routers only, or can you boot and "break" into ROMMON on a switch also?
Purple
Re: RMON - for routers only?
Yes any "IOS" switch you can break into rommon , this is how you do password recovery on most ios devices .
In most of the switches you need to use the mode button to break into rommon unlike using the keystrokes for routers.
Narayan
150
