rommon in 2960G
hello,
I have 2960G that in rommon status.
I need that the switch work in 0x2102 (regular mode).
I don't have a backup to configutratuio in my PC.
I do wr before the switch go to rommon (startup config).
What to do in order to the switch will be in 0x2102 (regular mode) with the same configuration( before the switch go to rommon)?
thanks...
Everyone's tags (1)
1 REPLY
rommon in 2960G
Can you please verify whether it is rommon or switch; prompt.
If it is in switch: prompt then follow the below.
switch:flash_init
switch:load_helper
switch:dir flash:
If you are able to see any IOS image in the flash then issue the below.
switch:boot flash:(image name)
525
