Rommon mode issue WS-C6506-E
Robo123
Hi Team,
I have cisco WS-C6506-E chassi running with "s3223-ipservicesk9_wan-mz.122-33.SXJ10.bin" suddently the device went to rommon mode by resetting the same came up and working fine but below errors are generated at the problamatic time .
(logs from crashinfo)
Sep 14 2017 15:56:12.495 IST: %SYSTEM_CONTROLLER-3-ERROR: Error condition detected: TM_DATA_PARITY_ERROR
Sep 14 2017 15:56:12.495 IST: %SYSTEM_CONTROLLER-3-FATAL: An unrecoverable error has been detected. The system is being reset.
(sh nvlog)
09/14/2017 15:56:12: nvlog_crash_hook:System crashed on slot 5. Check value of Rommon variable CRASHINFO
Kindly help me to know the root cause for the issue.
5 Replies 5
Reza Sharifi
There maybe some crash file on the flash.  I would open a ticket with TAC and send them the crash file for analyzes.
Hi Reza,
I am able to see only the above mentioned errors please  go through  those errors  and let me know  the root cause of the issue here 3 module is line card
WS-X6148A-RJ-45
 and 5 module is
WS-SUP32-GE-3B
Console into the line card in slot 5 and see if it's in ROMmon.
If it is in ROMmon, reboot the line card and post the entire boot-up process.
Hi Leo,
As i already said the device is came up while  goving reset commamd and the module 5 is passing the bootup level also.
Overall Diagnostic Result for Module 5 : PASS
Please let me know what is the below error saying.and why device went to rommon mode is it due to line card or sup faulty
The message means check the bootflash: for a sub-directory called "crashinfo". Inside there should be file(s) and look for the one with the latest date.
