09-02-2013 05:26 AM - edited 03-07-2019 03:15 PM
Hei,guys. As i got from the Cisco Official documents that the cmd to configure a root bridge has two styles. one is to set the switch to be root directly, and the other is to deploy the priority of the switch. However, I am confused by the cmd.
Switch(config)#spanning-tree Vlan 1 root primary
why should mention the Vlan 1 in the cmd. if it is the native vlan or other reasons?
Solved! Go to Solution.
09-02-2013 05:34 AM
On Cisco Switches you typically run one spanning-tree instance per VLAN (there are better ways if you have many VLANs like MST). So you can have different topologies configured in every VLAN. For that you can specify the vlan when setting the priority. And remember that the referenced command doesn't do anything else then setting the priority to a lower level.
So how do you use these multiple topologies?
If you have a "traditional" 3 layer network (core-distribution-access) you have two ways from access to your distribution layer. To use both uplinks you can set the root-bridge for half the VLANs to distribution-switch1 and the other half to distribution-switch2. By that you split your traffic over both links.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
12-12-2013 04:57 AM
Wei,
A gross simplification but perhaps helpful to you:
A good reading can be found here:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfc.shtml
http://blog.ine.com/2008/07/17/pvst-explained/
http://blog.internetworkexpert.com/2008/07/27/mstp-tutorial-part-i-inside-a-region/
http://blog.ine.com/2008/09/24/mstp-tutorial-part-ii-outside-a-region/
Best regards,
Peter
09-02-2013 05:32 AM
Hi Wei,
Cisco's STP implementation runs a separate copy of STP process for each VLAN. There is no "global" STP setting for a Cisco switch because there is no "global" STP process. All STP settings that can be done on a Catalyst switch always refer to a particular VLAN in which the corresponding STP instance runs.
So regardless of using the spanning-tree vlan vlan-range priority or spanning-tree vlan vlan-range root primary command, the VLAN number for which the switch priority is being modified must be explicitly specified.
Best regards,
Peter
09-02-2013 05:34 AM
12-11-2013 11:45 PM
Hello, i am not well in implementing STP. In fact, i don't know when and how to use every STP standards, like CST,PVST,MPVST and so on. can you show me details about these protocols. or show me some simple documents, configuration instance. thank you !
12-12-2013 04:57 AM
Wei,
Best regards,
Peter
12-12-2013 07:32 PM
Thank you very much.
