01-28-2014 08:03 AM - edited 03-07-2019 05:51 PM
We are plan to implement this kind of setup
Switch 1 --- connected with core switch 1
Switch 2
Switch 3
Switch 4
Switch 5 --- Connected with Core switch 2
Nornallay, we used to put root-guard on core side & loop guard on Access Side
But for the above case, what config needs to be put in between trunk of Switch2-Switch3 like that
Br/Subhojit
01-28-2014 08:08 AM
Can I ask why you are daisy chaining the switches like that?
Are the core switches VSS or using a First Hop Routing Protocol?
01-28-2014 08:11 AM
Due to less no of uplink port availability on Core switch side
Br/Subhojit
01-28-2014 08:12 AM
This are normal L2 switches only
Br/Subhojit
01-28-2014 08:32 AM
I think loopgaurd should be sufficient, as you will have rootgaurd configured on trunk interfaces of SW1 and SW5 going to Core1 and Core2 respectively.
Ankur
