07-07-2009 11:43 PM - edited 03-06-2019 06:38 AM
Hi All,
We have DC in Denmark connected to all locations through MPLS
from Denmark DC to Greenland we have one 512k direct p to p link routing protocol RIP was running
from Denmark DC to Aalborg p to p link, routing protocol OSPF
from Denmark Dc to Aalborg to Greenland we have one p to p link (Aalborg to Greenland static routes)
Now the present route from DC to Greenland passing on direct 512k p to p link
My present task is when this 512k link goes down the routes to greenland automatically should go through Denmark DC-> Aalborg-> Greenland
(Presently we are adding the routes manually when 512k link went down, but it should be automatically)
Naidu.
07-08-2009 04:55 AM
Why don't you add the weighted static routes for Greenland with Aalborg as the next-hop?
We know that Greenland is using RIP (AD 120) so your static routes can have an AD of 121 or greater.
Example,
ip route [Greenland_Subnet] [Aalborg_Gateway] 121
HTH,
__
Edison.
07-08-2009 06:12 AM
Hi Edison,
The present device is 4507R which have to use static route with weighted and the IOS is 12.2(20r)
Will it support for static route with weight?
Naidu.
07-08-2009 06:19 AM
Yes.
07-08-2009 09:53 PM
Hi Edison,
Thanks for your great help.
From Odense I have two networks need to reach greenland.
so shall i use same weight for both networks or different weights
Example:
10.23.0.0 255.255.255.0 10.17.4.1 122
10.24.0.0 255.255.255.0 10.17.4.1 122
Naidu.
07-09-2009 03:03 PM
Any weight that is higher than the RIP administrative distance - 122 is fine.
07-09-2009 09:34 PM
Hi Edison,
Thanks for you all help...
Have to discuss with my Management and will look into the production.
Once again thanks for your all responses.
Naidu.
07-09-2009 10:42 PM
Hi Edison,
My Manager raised one question is that below...
Now, my present setup is like Odense Coreswitch 4507 (no rip configured) -> Expand-box -> Greenland-router (rip configured)
If I add static routes with AD 122 in Coreswitch with next hop aalborg will it work as the Core dont know rip (i think still it sends packets to Greenland-router)
If I need to configure rip in Coreswitch, yet there are 2 ospf process running & BGP running now can i configure rip, will it ok with multiple routing protocols? and will it not give any problems in feature?.
Naidu.
07-10-2009 07:41 AM
Based on your current setup, Odense does not have any routing information for Greenland (if I understand you correctly) so any routing information will be used regardless of the weight of the administrative distance.
My previous recommendation was based on Odense having RIP routes from Greenland router and placing statics as backup.
07-12-2009 06:15 AM
Hi Edison,
So, as per your explaination I have to advertise RIP in Odense is that right?
Naidu
07-12-2009 07:25 AM
You keep changing the network setup. Can you provide a diagram of what's currently implemented on the network and what's the end goal?
Without this information I won't be able to provide a concise answer.
__
Edison.
