ola
route leakage
I have question about routing.
I have a 6500 running 12.2(18)SXF15 with a vrf pointing towards my monitoring server. How can I get the SMNP traps routed from the global table to the vrf?
Well routing should of course work both ways.
/Ola
Hall of Fame Super Silver
Re: route leakage
Hello Ola,
look if there is a vrf option in the command that specifies the source for SNMP traps
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_20.html#wp1024558
unfortunately I don't see this vrf option in command
snmp-server source interface as it happens in other commands
so actually a route leakage approach is needed in your case.
one way could be the following:
associate an ip subnet both to the VRF and to the GRT.
vlans X and Y connect with a crossover cable one access-port in vlan X with one port in vlan Y.
and
ip route trap-server 255.255.255.255 vlanX
snmp-server source interface vlan X
Hope to help
Giuseppe
ola
Re: route leakage
Hi Giuseppe,
Thank you for the tip.
I will try that and see if it will solve my problem.
Kind regards
/Ola
ola
Re: route leakage
Hi again Giuseppe,
Do you know of any way to solve it with internal routing instead of a physical cable. The reason I ask is because because there is a bit to travel to get to the 6500.
/Ola
174
