Community Member
Route leaking from VRF to Global
Hi , I want to leak routes from one VRF to the global routing table.  I can do this with statics, but is ther a dynamic way to do this.
I can leak from the Global to the VRF no problem using the following commands, but I cant figure out how to do it from VRF to global except for using statics on the global routing table
ip vrf testvrf
rd 65000:4
import ipv4 unicast map global
route-map global permit 10
match ip address prefix-list globallist
ip prefix-list globallist seq 5 permit 10.0.0.0/24
ip prefix-list globallist seq 10 permit 192.168.2.0/24
Are the routes in BGP? Which IOS version are you running?
http://mellowd.co.uk/ccie/?p=3645
This post shows how you can do export if you have a recent IOS with the export command.
Daniel Dib
CCIE #37149
Daniel Dib CCIE #37149 Please rate helpful posts.
Community Member
Hi Daniel. I am running 12.4 on a 2800 router. I saw that post also and noticed that export command but my version does not have it.  Is there another way besides export or static routes
Its relatively simple to do this between VRFs that it seems difficult to believe that its that complex from VRF to Global
Carlos Vazquez
CCIE # 20702
Community Member
im also facing the same
im also facing the same challenge. im using 7200 Cisco router C7200-ADVIPSERVICESK9-M), Version 15.1(4)M2 . the Export option under ip vrf does not include the ipv4 option.
regards
Promise Kumalo
Community Member
Hi,  The export ipv4/ipv6
The export ipv4/ipv6 unicast command is only a very recent command, and is supported on the latest IOS versions. Other than that there is no way of Route Leaking between VRF and Global Routing Table Dynamically.
HK
Community Member
hi HK i also tried this on
hi HK
i also tried this on the new cisco 2911 router with data license loaded. the ipv4 option is still not there on the export command
Community Member
Hi, Please check the below
Please check the below link.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/xe-3s/asr1000/irg-xe-3s-asr1000-book/irg-prefix-export.html
HK
772
