Silver
Route-Map and ACL question
I have an interesting scenerio, it is only for testing purposes and not what we will use for production. This is just for testing! Here is what I am trying to do.
I have a VLAN that is set-up for all workstations:
VLAN 100
interface Vlan100
description VLAN-100
ip address 10.1.0.1 255.255.240.0
ip ospf priority 10
ip policy route-map VLAN100_POLICY
In this router/msfc we are running EIGRP and OSPF, now this is now where the issue is at, this is pretty straight forward. We then have a default route:
ip route 0.0.0.0 0.0.0.0 192.168.3.10
This is the interface IP on the firewall.
In this path there is a proxy 192.168.3.5
Here is the route-map that is applied to the VLAN interface:
route-map VLAN100_POLICY permit 10
match ip address GOTO_FIREWALL
set ip default next-hop 10.254.1.10
In this acl we have IP's that will be used to bypass the proxy. The list is quite long so I will not bore you all with the info.
Ok onto what I need to do.
I am setting up a new proxy with more features and need to test a handful of users. I have my IP 10.1.15.100 that needs to take a different path:
New VLAN103 192.168.103.1
New proxy 192.168.103.5
New firewall interface 192.168.103.10
Here are the ACL's I have created so far:
ip access-list extended BYPASS-BC2-TO-DMZ
permit ip host 10.1.15.100 192.168.0.0 0.0.255.255
ip access-list extended BYPASS-BC2-TO-E1
permit ip host 10.1.15.100 10.1.252.0 0.0.0.255
ip access-list extended GOTO-BLUECOAT2
permit ip host 10.1.15.100 any
And the route-maps for manipulation:
route-map VLAN100_POLICY permit 15
match ip address BYPASS-BC2-TO-DMZ
set ip next-hop 10.254.1.10
route-map VLAN100_POLICY permit 20
match ip address GOTO-BLUECOAT2
set ip next-hop 192.168.103.10
I am trying to get internal access set-up and having a difficult time.
For instance I need to get to 10.1.252.54, which is directly connected:
interface Vlan252
description VLAN252-CSM
ip address 10.1.252.1 255.255.255.0
MONR001#sh ip route 10.1.252.54
Routing entry for 10.1.252.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 555, ospf 100
Advertised by ospf 100
Routing Descriptor Blocks:
* directly connected, via Vlan252
Route metric is 0, traffic share count is 1
Is there a way to get my workstation to go to 10.1.252.0/24 network with a route-map to a directly connected IP?
Re: Route-Map and ACL question
If I understand your question correctly, what you need is just to use PBR to route your traffic to the specified host. So, you need apply the related route-map under the interface of the Vlan where your PC 10.1.15.100 is in.
Silver
that is the question.
I know I need a PBR to get the traffic where I need it. The question in all of this is how do you build the PBR for a directly connected network.
I think I provided enough detail in the post, at least I hope, to explain what I am trying to do.
Can you clarify your topology?
10.1.252.0/24 is directly connected to MONR001, is your pc 10.1.15.100 directly connected to this router as well?
If not, is MONR001 the last hop for 10.1.15.100 to access 10.1.252.0/24 network?
Silver
On the 6509 MSFC I have the following
interface Vlan100
ip ospf priority 10
This is my default route for my workstation
Also on this same 6509 is:
interface Vlan252
This is the network I am trying to get to.
In this set-up according to my routing policy set-up I have a default route of 0.0.0.0 0.0.0.0 192.168.3.10
So if something does not match the policy applied to interface vlan 100 the traffic will go here.
So from a topology standpoint these networks are all local that I am referring to, which is why the networks show directly connected.
How do you create a PBR to a directly connected network?
Is it possible?
This is what I am trying to do.
Ok, I hope I understood it now.
Saying you would like your PC to access 10.1.252.0/24 network which is a directly connected network to the same 6509, do you want to forward the packet to a specified host first? If not, why don't you just let routing table make the decision? If yes, just use related "match ip address " and "set ip next hop x.x.x.x" command in your route-map. Make sure there is no overlap entry in your existing ACL "GOTO_FIREWALL".
Silver
I cannot let routing make the decision because I am trying to manipulate the routing table because of the test I am trying to run. I am trying to send traffic to a new location for internet, and non directly connected networks and that is just fine. When trying to direct that host to a local network it normally has access to it does not route. I need some way to do this via PBR. What you propose is cannot be technically done, IOS will not allow you to use a next-hop to an IP that is self, in this case the directly connected network? I am looking for a way to get around this.
179
