09-19-2013 07:59 AM - edited 03-07-2019 03:34 PM
I set up a route-map,
by cons it does not work, for info I have a default route to the ISP 2
ip route 0.0.0.0 0.0.0.0 172.24.1.1,
when I do a tracert I see it through the ISP2 link then I want it to ISP1 goes through the tunnel.
here is the config:
interface Vlan91
description Chicago
ip address 172.24.5.2 255.255.255.0
ip helper-address 172.20.0.251
ip policy route-map myMap
access-list 101 deny ip 172.24.5.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 deny ip 172.24.5.0 0.0.0.255 172.34.0.0 0.15.255.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 172.24.5.0 0.0.255.255
access-list 101 permit tcp 172.24.5.0 0.0.0.255 any
route-map permit 10 myMap
match ip address 101
set ip next-hop 192.168.255.62
Thank you.
Solved! Go to Solution.
09-19-2013 08:27 AM
Where does the IP address of 192.168.255.62 sit in your network?
Can you show us the routing table on this router?
09-19-2013 08:04 AM
Traceroute uses udp/icmp (depending on the implementation) and you are matching on tcp only. Try changing "access-list 101 permit tcp 172.24.5.0 0.0.0.255 any" to "permit ip" and test again...
HTH,
John
*** Please rate all useful posts ***
09-19-2013 08:10 AM
Hi John,
I just change it but still not
I guess the road map is not compatible with the next hop to the tunnel (knowing that I ping the other tunnel interface), you're agree with me?
James,
09-19-2013 08:27 AM
09-19-2013 08:44 AM
Communication is established between the tunnel:
there is no problem on the routing,but does not working !!!
this is a tracert from my host:
C:\Documents and Settings\XXXXX>tracert 192.168.255.62
Détermination de l'itinéraire vers 192.168.255.62 avec un maximum de 30 sauts.
1 12 ms 1 ms 2 ms 172.24.5.2
2 45 ms 41 ms 49 ms 192.168.255.62
Itinéraire déterminé.
C:\Documents and Settings\XXXXX>tracert 192.168.255.63
1 24 ms 1 ms 1 ms 192.168.255.63
09-19-2013 08:54 AM
I did something wrong, my concern is not solved yet.
09-19-2013 09:03 AM
