Route-map (next hop to tunnel)
csco11579831
I set up a route-map,
by cons it does not work, for info I have a default route to the ISP 2
ip route 0.0.0.0 0.0.0.0 172.24.1.1,
knowing that the ping is ok between tunnels,
when I do a tracert I see it through the ISP2 link then I want it to ISP1 goes through the tunnel.
here is the config:
interface Vlan91
description Chicago
ip address 172.24.5.2 255.255.255.0
ip helper-address 172.20.0.251
ip policy route-map myMap
access-list 101 deny ip 172.24.5.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 deny ip 172.24.5.0 0.0.0.255 172.34.0.0 0.15.255.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 172.24.5.0 0.0.255.255
access-list 101 permit ip 172.24.5.0 0.0.0.255 any
route-map permit 10 myMap
  match ip address 101
  set ip next-hop 192.168.255.62
Thank you.
5 Replies 5
cadet alain
what does debug ip policy is telling ?
Alain
csco11579831
I just did another test by changing the next hop to the nearest jump (G0/0) from my BBO, and I managed to redirect the flow to the router interface in front of me, so this confirms the route-map is not compatibe with tunneling?
Agree with me are you?
Please have a solution?
Best Regards,
James
Hi Cadet,
there is no ip policy, i use a simple GRE tunnel,
interface Tunnel1
description vers XXXX
ip address 192.168.255.63 255.255.255.252
tunnel source "@ ip of BBO"
tunnel destination "@ ip of remote BBO 6500"
interface Tunnel1
description vers YYYYY
ip address 192.168.255.62 255.255.255.252
tunnel source "@ ip of remote BBO 6500"
tunnel destination "@ ip of BBO"
int vlan 1
ip policy route-map xxx  ----> there is ip policy
I suppose you want the traffic matched in the route-map to go inside the  GRE tunnel ?
when debug ip policy is turned on what is the output when you initiate traffic that matches your route-map ?
Alain
i can't launch a debug ip policy,it may be that overloading CPU of the BBO,
