Route map question
I have the following config :
access-list 100 remark ** Net_1 **
access-list 100 permit ip 10.60.64.0 0.0.7.255 any
access-list 101 remark ** Net_2 **
access-list 101 permit ip 10.60.80.0 0.0.15.255 any
access-list 102 remark ** Net_3 **
access-list 102 permit ip 172.30.130.0 0.0.0.255 any
route-map EEMM permit 10
match ip address 100
set ip next-hop 167.175.1.1
route-map EEMM permit 20
match ip address 101
route-map EEMM permit 30
match ip address 102
route-map EEMM permit 40
interface FastEthernet2/2
no switchport
ip address xxx.xxx.xxx.xxx 255.255.255.248
ip policy route-map EEMM
When I apply the ip policy route-map EEMM on the interface it works good because I can see on the firewaall that traffics from ACL 100-102 go to next-hop 167.175.1.1.
But when I do a show route-map I dont see any match.
Any idea of what is happening?
I am using a Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.1(20)EW1
1 REPLY
Hall of Fame Super Silver
Re: Route map question
Hello Leonardo,
you are using a multilayer switch.
What happens is that the route-map is used to build / rebuild the CEF entries in the CEF table and the actions of the route-map are actually performed on the TCAM tables of the switch.
This allows for high performance PBR but actually traffic is not processed by the route-map but some TCAM entries are built following the route-map instructions.
So you could see the route-map that doesn't match even if traffic flows are correctly sent to the right next hop as you see.
This behaviuor can change on another platform and/or IOS release, simply because when building the sh route-map the IOS code can look for the flow counters of the TCAM entries built on the route-map and give us the effect that the route-map matches.
However, PBR works on incoming traffic so it has to be configured on the interfaces where the traffic flows enter at the node.
Hope to help
Giuseppe
98
