router 1841 remote access
I am having problem with our Cisco router 1841. I configured it for vpn remote client access and it works, but once connected I can't remote access the server inside the network. I can mount the root drive but can't browse the folder in the drive. I can mount the individual folder inside the drive but can't open files someone has created in that drive. Is this router config problem or file server? Router has IOS 12.4 and the file server is running Windows 2000 server.
Also, I would like to remote access the file server from outside without using vpn. Should I use standard access list or extended? Any sample config will be appreciated.
1 REPLY
Re: router 1841 remote access
This seems to be a file server priviledge problem.
If you are connecting to the filesever without VP use extended access-list for more granular filtering of the traffic.
-amit singh
120
