ā01-03-2012 05:09 AM - edited ā03-07-2019 04:08 AM
how many vlans can i create in router 2911.
i have created four sub interfaces with vlans, but only two are working/pinging, is there any limitations of vlan or sub int created.
wavecrest# sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 23-Feb-11 15:41 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
wavecrest uptime is 3 days, 1 hour, 36 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M5.bin"
Last reload type: Normal Reload
thanks
srikanth
ā01-03-2012 05:14 AM
Hi srikanth,
There is no any limitations having subinterfaces on router but we need to consider the load on the router.
If you are unable to ping the vlan interface then it doesnt mean that there is limitation.
Make sure you have atleast interface associated with that vlan (which is not pinging).
And make sure the vlan is created in vlan database file.
And finally what is the vlan status?
Please rate the helpfull posts.
Naidu.
ā01-03-2012 06:23 AM
Hi Srikanth,
4 sub interfaces is not a big number. your router should be able to support that.
can you share the following:
1. your running configuration.
2. show int vlan
-Vijay
ā01-04-2012 03:10 AM
the interface is not up after assigning an ip to it or in the sub interface..
im using two interface for LAN and ONe for Wan..
gig0/0 ------is UP-----and all the sub interface Ips i can see in the sh ip route command.
gig 0/2 -----is not up -----and i dont even see the IP as the connected subnet in sh ip route.
here is the major difference i have seen
avecrest#sh controllers gigabitEthernet 0/0
nterface GigabitEthernet0/0
= Hardware =
ardware is PLATFORM SGMII INTERFACE
WIDB: 30B3D33C, INSTANCE: 2933D400, FASTSEND: 21192EC0, MCI_INDEX: 0
oute Cache Flag: 11
Software filtered frames: 221
Unicast overflow mode: 0
Multicast overflow mode: 1
Promiscuous mode: 0
Total Number of CAM entries: 1
Port Stopped: N
Internal Loopback Set: N
2.
wavecrest# sh controllers gigabitEthernet 0/2
Interface GigabitEthernet0/2
= Hardware =
Hardware is PLATFORM SGMII INTERFACE
HWIDB: 30B5FEF0, INSTANCE: 30B60C00, FASTSEND: 21192EC0, MCI_INDEX: 0
Route Cache Flag: 11
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 0, TX_TAIL: 0
TX_MIN_SIZE: 32, TX_MAX_SIZE: 512, TX_CURRENT_SIZE: 128
RX STARVES: 0
Software MAC Address Filter (hash:length/addr/mask/hits)
0x000: 0 ffff.ffff.ffff 0000.0000.0000 0
0x093: 0 4055.39b8.1faa 0000.0000.0000 0
0x0C0: 0 0180.c200.0002 0000.0000.0000 0
0x0C0: 1 0100.0ccc.cccc 0000.0000.0000 0
0x0C5: 0 0180.c200.0007 0000.0000.0000 0
Software filtered frames: 0
Promiscuous mode: 0
Port Stopped: Y
ā01-04-2012 05:42 AM
hi,
post your config and output from:
sh int g0/0 and sh int g0/2
sh ip int br and sh ip route
Regards.
Alain
