Router 3600
Hi Everybody.
when start my router 3600 across the console , it show the next content
It´s normal this POST?
The running of the router is normal, although It loss the comnunication 2 or 3 times per week , , but after  I restart, It´s running correct.
I have seen that Smart Init is enabled, ....and It show the memory positions...
Thanks Community
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0x864e20
Self decompressing the image : #################################################
######################################## [OK]
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0000DA          0X0004FE00 Single Port Fast Ethernet
0000D6          0X000D8A10 FE Port Module, 2 WAN
                0X00280000 OIR memory
                0X000F3BB0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X00785DD0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 8Mb.
Using 12 percent iomem. [8Mb/64Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3600 Software (C3660-I-M), Version 12.3(2)T1,  RELEASE SOFTWARE (fc2)
Synched to technology version 12.3(1.9)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 22-Aug-03 23:31 by dchih
Image text-base: 0x600089B8, data-base: 0x60DA0000
cisco 3660 (R527x) processor (revision 1.0) with 57344K/8192K bytes of memory.
Processor board ID JHY0735K1JQ
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
3660 Chassis type: ENTERPRISE
1 FastEthernet/IEEE 802.3 interface(s)
6 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
Router 3600
Hi, this output is normal. No problems are shown.
I suggest you to upgrade IOS with a fresh release, e.g. 12.4.
Regards.
Router 3600
Thanks Dadiele,
Could you to recomend for me some tools for verify the stress of routers?
Best regards
Router 3600
How do you mean 'the stress'?
113
