Router 891 and wep wlan
Good afternoon,
We have a cisco router cisco 891 (c890-universalk9-mz.152-4.M3.bin), and we have problems to connect a wep wlan.
When the client try to connect appears searching IP and then he is disconnected.
The network is so simple, an autonomous A.P connect directly to router and the router is the DHCP server by the wlan.
We have another cisco router 891 with the same config connects an AP with wpa wlan and It works well.
We can not change the authentication wlan because some client only can connect via wep. Any idea?
Thanks for your help,
Regards.
Everyone's tags (2)
109
