11-06-2006 08:45 AM - edited 03-05-2019 12:38 PM
Hi all, If i have a dsl connection at home, with a cisco dsl router and pix 501 firewall, where do i do the natting and what routes need to be on where ?
11-06-2006 09:16 AM
Hi Carl,
Your DSL router will be having the public IP from your ISP on its DSL interface. So you have to NAT it on the ADSL interface. You will have a private IP on the router connecting to the outside interface of the PIX. So do a self static on the outside interface and use ACLs to allow or deny the traffic and NAT it on the router interface for the outgoing internet traffic.
HTH, Please rate if it does.
-amit singh
11-06-2006 09:16 AM
Hi Carl,
-amit singh
11-07-2006 08:52 AM
do you mean a nat overload ? can you give me an example config of these connected devices ?
11-07-2006 09:31 AM
here is a sample config
ip nat inside source list 101 interface fastEthernet0/0 overload
access-list 101 permit ip 172.16.100.0 0.0.0.255 any
access-list 101 permit ip 172.16.200.0 0.0.0.255 any
interface fa 0/1
ip address 200.200.200.200 255.255.255.0
ip nat inside
interface fa 0/0
ip address 172.16.100.1 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 fa 0/1
HTH, rate if it does
Narayan
11-07-2006 01:08 PM
thanks
