Router buying advice
Hi guys!
I have to change a linux routing to a router to do only a small NAT. In once side i have a PLC (ip 192.168.1.65/24) that need to see 8 PLC in network another network (192.168.0.0/24) as "localnet" ips (it don't route). In the 192.168.0.0/24 side i have only 1 ip (192.168.0.80) and all the conection are "masquerade".
Now i have the networks in 2 nic of the linux box.
The problem that i have is... what's the router right for my?
It have a traffic is really low (like 10Kbps), but it have to be robust because it route connections for a electrical generation plant that work 24/7.
All advice are welcome!
Everyone's tags (4)
1 REPLY
Re:Router buying advice
Mission critical? I would look at 2 routers each with 2 nics running hsrp.
Sent from Cisco Technical Support Android App
217
