Webcast-Catalyst9k
Router can`t ping outside while Inside users can ping outside
I have problem with my router.
In my topology  ISP connected with my router and then  swithces connected to routers.This is simple topology.
from router i can`t ping  outside.For example ping 8.8.8.8  and ping failed.While  Pc from internal  can ping 8.8.8.8
also from  routee i can`t ping it`s own external interface.while Pcs also can ping it
All Pcs have internet connection ,while  router haven`t
there is my configuration
interface GigabitEthernet0/0
description Link To Internet
ip address 146.255.XX.XX 255.255.XX.XX
ip access-group 110 in
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip nat inside source route-map nat interface GigabitEthernet0/0 overload
route-map nat permit 10
match ip address 135
access-list 135 permit ip 172.16.87.0 0.0.0.127 any
When in configuration i delete command  ip nat outside .then i can ping from router outside.after it i write command ip nat inside.
while  1-3 hours i can ping outside.but then can`t ping  outside and it`s own external interface
I
Can anyone meet with this problem ?
2 ACCEPTED SOLUTIONS
Purple
Can you get rid of ip nat enable command on both interfaces and let us know and if it still ain't working could you post sh access-list 110 output.
Alain
Purple
Can you post the entire config and  also do this:
access-list 99 permit icmp host x.x.x.x  8.8.8.8   where x.x.x.x is your WAN IP
logging monitor 7
logging console 7
no serv timestamp debug
do debug ip pack detail 99
do debug ip nat 99 detailed
Then do your ping from the router to 8.8.8.8 and post results.
Alain
Purple
Can you post your sanitized running config.
Alain
hi
This is my working configuration
ip address  XXXXXXXXXXX
ip nat outside
ip nat enable
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 85
ip address 172.XXXXXX 255.XXXXXXX.0
ip nat inside
ip nat enable
no keepalive
Purple
Alain
I delete command ip nat enable on both interfaces.
There is ACL 110
access-list 110 permit ip host XXXXXx any
access-list 110 permit ip host XXXXXX any
access-list 110 permit ip host XXXXX any
access-list 110 deny   tcp any any eq 1720
access-list 110 deny   tcp any any eq 5060
access-list 110 deny   tcp any any eq 5061
access-list 110 deny   udp any any eq 5061
access-list 110 deny   udp any any eq 5060
access-list 110 deny   tcp any any eq 1719
access-list 110 deny   tcp any any eq 1718
access-list 110 deny   tcp any any eq 2099
access-list 110 deny   udp any any eq 1720
access-list 110 deny   udp any any eq 1719
access-list 110 deny   udp any any eq 1718
access-list 110 deny   udp any any eq 2099
access-list 110 deny   tcp any any eq telnet
access-list 110 deny   tcp any any eq www
access-list 110 deny   tcp any any eq 22
access-list 110 permit ip any any
Purple
So I conclude it is still not working with both ip nat inside and ip nat outside on corresponding interfaces for router to internet communication ?
Alain
Hi.You are right
I still can`t ping outside from router while users inside can ping outside and have internet.
Yesterday also was this issue.I deleted command  ip nat outside ,then ping 8.8.8.8 and again write command ip nat outside.It was working till today.I try to do same but it wasn`t helpful
also i have  statis nat
ip nat inside source static XXXXX interface GigabitEthernet0/0
Purple
logging monitor 7
logging console 7
Alain
I do same. in access list 99 there is no permit icmp because of it i choose acl 100
IP: s=146.255.241.58 (local), d=8.8.8.8, len 100, local feature
    ICMP type=8, code=0, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
FIBipv4-packet-proc: route packet from (local) src 146.255.241.58 dst 8.8.8.8
FIBfwd-proc: packet routed by adj to GigabitEthernet0/0 146.255.241.57
FIBipv4-packet-proc: packet routing succeeded
IP: s=146.255.241.58 (local), d=8.8.8.8 (GigabitEthernet0/0), len 100, sending
    ICMP type=8, code=0
IP: s=146.255.241.58 (local), d=8.8.8.8 (GigabitEthernet0/0), len 100, output feature
    ICMP type=8, code=0, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, IPSec output classification(34), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, NAT ALG proxy(59), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, IPSec: to crypto engine(76), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Post-encryption output features(77), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
IP: s=146.255.241.58 (local), d=8.8.8.8 (GigabitEthernet0/0), len 100, pre-encap feature
    ICMP type=8, code=0, IPSec Output Encap(1), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
    ICMP type=8, code=0, Crypto Engine(3), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
IP: s=146.255.241.58 (local), d=8.8.8.8 (GigabitEthernet0/0), len 100, sending full packet
    ICMP type=8, code=0.
    ICMP type=8, code=0
    ICMP type=8, code=0
    ICMP type=8, code=0
    ICMP type=8, code=0
4547
