Router command
Can anybody tell me what is router in sticky in EIGRP.
Naidu.
Silver
Re: Router command
Do you mean router "stuck-in-active" in EIGRP?
If so, the following link gives details :
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008010f016.shtml
Niranjan
(pls rate helpful posts)
Re: Router command
Hi Niranjan,
Appologies for my mistake,
yes your right with "stuck-in-active" in EIGRP.
However your mentioned link helps me.
Naidu.
Silver
Re: Router command
hi!
Can you rate the post if it has helped?
Niranjan
89
