Router Config Assistance (Stub Network on Static WAN)
Ok, I will be the first to tell you that I do not have "Real World" experience with Cisco routers
I did take CCNA 1-4 in school several years ago - and honestly, forget most of it due to no use.
So I'm one of those "do more damage kind of people"
Tomorrow (August 8th,2008) - I will be putting the router to test for a few hours. This test will be
to make sure outbound connectivity is there and hopefully finding out if exchange still works and PPTP to
windows still works. Our IP's have changed with this service - meaning I have one months grace before
switch services.
Concerns:
VPN -> I can connect to the VPN Server and obtain an IP, no gateway displayed (no connectivity)
VPN -> Not sure if you can set VPN Security Policies (ACL's) per user. See additional notes in next section
Servers --> Are things setup to allow connections properly with NAT to our server and their services.
DHCP --> do I need to forward DHCP, since it's handled by Windows Server
Any advice would be great.
See attached for Running Config
Internal Servers
Windows 2003 Small Business Server IP: 10.0.0.15 / VPN on 10.0.0.19 I believe!
AD configured as mydomain.local
DNS requests are forwarded to ISP
SBS Exchange -using Webmail with SSL certificate (Port:443)
SBS VPN (PPTP) being used as VPN solution for staff.
Additional Notes:
- Replacing Cisco 800 router owned by ISP, no configurable options with 871w that we purchased.
- Changed DSL package to Static, 5-IP , no PPP
- We are replacing a SOHO Watchguard with the Cisco 871w because it's dying
- Watchguard has 5 vpn licenses, only 1 in use with external client who gets the ip 10.0.0.249. The
client connects, this allows us to send invoices/purchase orders to their line printer.
* This functionality needs to be setup on the Cisco 871w. I would like to see 1 way communication - so client
could not access local resources.
External DNS
* all addresses are examples
IN A <isp IP>
www IN A <isp IP>
ftp IN A <isp IP>
remote IN A 192.168.100.230
remote1 IN A 172.16.0.139 ** Added to point to 1 new static IP
webmail IN A 192.168.100.230
IN MX 10 remote.domainname.com.
IN MX 15 remote1.domainname.com. ** Added
pop3 IN CNAME <ISP hostname>
smtp IN CNAME remote.domainname.com.
Additional switch will be: webmail will point to 172.16.0.140
222
