Router connected to a routed port
Can you connect router ethernet interface to a switch routed port. if yes what is the benefit? Thx
Silver
Re: Router connected to a routed port
yes it is possible. this could be usefull for example to make dynamic routing between the router and the L3 interface in the switch.
The primary benefit of connecting a router to a switch's routed port is any spanning tree issues in the network wouldn't affect the routing between the switch and router. If it's an option it's desirable to setup routing this way.
Sundar
Would I need a crossover cable to coonect.
Thx
I know straight through cable works fine for this setup.
Sundar
132
