05-31-2012 08:43 PM - edited 03-07-2019 07:00 AM
Hello Experts:
Can somebody confirm the troubleshooting steps in order to find out the root cause of the router reboot. I would see all the steps to grab the information to know the actual root cause of the failure. Thanks...
Solved! Go to Solution.
06-03-2012 08:21 PM
Now, I need to investigate what was happened & it caused the network slowness. Thanks.
Need more information than this.
1. WHAT is slow? Application? Login? Sending/receving emails? Internet?
2. Is it slow across the board or slow with one application and the rest are fine?
3. Everyone experiencing this problem or ALL are experiencing this problem?
4. Describe your network?
05-31-2012 08:59 PM
Can you please post the output to the following commands:
1. sh version;
2. dir
05-31-2012 10:33 PM
make external syslog and so you'll find your answer
06-01-2012 12:53 AM
Hi Ray,
This is what you can do:
1. Check "show version" for last reload or "return to rom" reason line.
2. Check on SYSLOG server for the messages router managed to send before goign down.
3. Check connected file systems for the crashinfo file (typically flash or bootflash) and research its contents. You can read the file by "more ..." command or by ftp'ing it to your server/PC first.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
06-03-2012 06:32 PM
This is what i get:
Please explain the root cause of the issue by analysing the logs stated below for your reference.
router#sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(25a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 22-May-09 22:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
router uptime is 2 hours, 54 minutes
System image file is "flash:c2800nm-spservicesk9-mz.124-25a"
export@cisco.com.
Cisco 2811 (revision 53.51) with 393216K/131072K bytes of memory.
Processor board ID FGL151110X2
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
router#
router#sh log
Syslog logging: enabled (11 messages dropped, 1 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 27 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
No active filter modules.
Trap logging: level notifications, 29 message lines logged
Logging to x.x.x.x (global) (udp port 514, audit disabled, link up), 29 message lines logged, xml disabled,
filtering disabled
--More--
Log Buffer (8192 bytes):
*Jun 3 192.168.1.1: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 3 192.168.1.1: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Jun 3 192.168.1.1: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Jun 3 192.168.1.1: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to down
*Jun 3 192.168.1.1: %LINK-3-UPDOWN: Interface Serial0/0/1, changed state to down
*Jun 3 10.0.0.1: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Jun 3 10.0.0.1: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Jun 3 10.0.0.1: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to down
*Jun 3 10.0.0.1: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/1, changed state to down
*Jun 3 x.x.x.x: RSA key size needs to be atleast 768 bits for ssh version 2
*Jun 3 x.x.x.x: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1111, changed state to up
*Jun 3 x.x.x.x: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback11, changed state to up
*Jun 3 x.x.x.x: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Jun 3 x.x.x.x: %LINK-5-CHANGED: Interface Serial0/0/1, changed state to administratively down
*Jun 3 x.x.x.x: %SYS-5-CONFIG_I: Configured from memory by console
*Jun 3 x.x.x.x: %SYS-5-RESTART: System restarted --
*Jun 3 x.x.x.x: %SNMP-5-COLDSTART: SNMP agent on host router is undergoing a cold start
*Jun 3 x.x.x.x: %SSH-5-ENABLED: SSH 1.5 has been enabled
*Jun 3 x.x.x.x: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to up
*Jun 3 x.x.x.x: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host x.x.x.x started - CLI initiated
*Jun 3 x.x.x.x: %LINEPROTO-5-UPDOWN: Line protocol on Interface , changed state to up
*Jun 3 x.x.x.x: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to up
*Jun 3 x.x.x.x: %BGP-5-ADJCHANGE: neighbor x.x.x.x Up
*Jun 3 x.x.x.x: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Jun 3 x.x.x.x: %BGP-5-ADJCHANGE: neighbor 54.142.83.2 Up
*Jun 3 x.x.x.x: %WCCP-5-SERVICEFOUND: Service 61 acquired on WCCP client x.x.x.x
*Jun 3 x.x.x.x: %WCCP-5-SERVICEFOUND: Service 62 acquired on WCCP client x.x.x.x
router#
router#
router#exit
06-03-2012 07:26 PM
The router was either rebooted or someone turned the power ON to the router.
Can you please post the output to the command "dir"?
06-03-2012 07:44 PM
while executing the command, I am getting this error:
router#dir
Command authorization failed.
router#dir
06-03-2012 07:54 PM
router#dir
Your username does not have the right access level to invoke this command.
06-04-2012 06:12 PM
Today there is another alert recieved of router down... checked the router via sh ver where it was not rebooted. check the logs stated below:
Anything happened wrong... I changed the public IP with private IP's.
Jun 4 15:39:57: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1521, changed state to up
Jun 4 15:40:25: %BGP-5-ADJCHANGE: neighbor 192.168.1.1 Up
Jun 4 15:43:00: %BGP-5-ADJCHANGE: neighbor 192.168.1.1 Down BGP Notification sent
Jun 4 15:43:00: %BGP-3-NOTIFICATION: sent to neighbor 192.168.1.1 4/0 (hold time expired) 0 bytes
Jun 4 15:44:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1521, changed state to down
Jun 4 15:52:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1521, changed state to up
Jun 4 15:52:31: %BGP-5-ADJCHANGE: neighbor 192.168.1.1 Up
Jun 4 17:03:47: %BGP-3-NOTIFICATION: received from neighbor 192.168.10.10 4/0 (hold time expired) 0 bytes
Jun 4 17:03:47: %BGP-5-ADJCHANGE: neighbor 192.168.10.10 Down BGP Notification received
Jun 4 17:04:20: %BGP-5-ADJCHANGE: neighbor 192.168.10.10 Up
Jun 4 17:04:36: %BGP-5-ADJCHANGE: neighbor 192.168.10.10 Down Peer closed the session
Jun 4 17:05:02: %BGP-5-ADJCHANGE: neighbor 192.168.10.10 Up
Jun 4 18:18:06: %VPN_HW-1-PACKET_ERROR: slot: 0 Packet Encryption/Decryption error, Output Authentication error:srcadr=192.168.20.20,dstadr=192.168.30.30,size=1456,handle=0x581B
Jun 4 18:18:06: %CRYPTO-4-RECVD_PKT_MAC_ERR: decrypt: mac verify failed for connection id=2027 local=192.168.30.30 remote=192.168.20.20 spi=45422A6E seqno=0000066B
Jun 5 00:57:23: %VPN_HW-1-PACKET_ERROR: slot: 0 Packet Encryption/Decryption error, Output Authentication error:srcadr=192.168.20.20,dstadr=192.168.30.30,size=120,handle=0x5809
Jun 5 00:57:23: %CRYPTO-4-RECVD_PKT_MAC_ERR: decrypt: mac verify failed for connection id=2009 local=192.168.30.30 remote=192.168.20.20 spi=E3497154 seqno=000015B1 Jun 4 15:39:57: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1521, changed state to up
06-03-2012 07:59 PM
If the router is on a ups I would say the power supply is on its way out.
06-03-2012 08:14 PM
I would need to know the troubleshooting steps on router to determine the root cause of the network slowness as one of the user reporting that the network was very slow but after 4hrs its working fine w/o problem.
06-03-2012 08:21 PM
06-03-2012 08:32 PM
Well, we have around 10 sites connected via MPLS and network slowness issue was experienced by entire users for internet traffic and internal remote traffic which go via MPLS but it has been resolved.
I know that by monotoring the interface using monitoring tools we may see the bandwidth spike which could be a possible reason of this problem but can we check anything like interface details or something to know the same if suppose we don;t use any monitoring tools and what steps would you recommend if we face this issue live... Thanks.
06-03-2012 10:15 PM
How big is your MPLS WAN link? Is the site being serviced by a 2801 router?
