02-06-2014 12:23 AM - edited 03-07-2019 06:02 PM
Hi, just got brand new 3945E with following config:
no ip source-route
ip arp proxy disable
ip cef
interface Tunnel1
ip address 10.95.62.5 255.255.255.252
ip flow ingress
ip flow egress
!it's default route to all networks
interface GigabitEthernet0/0
no ip address
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/0.18
encapsulation dot1Q 18
ip address 10.96.249.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1.602
encapsulation dot1Q 602
ip address 172.30.123.1 255.255.255.252
interface GigabitEthernet0/2
no ip address
no ip proxy-arp
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/2.17
encapsulation dot1Q 17
ip vrf forwarding Management
ip address 10.96.32.61 255.255.255.0
no ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip flow-top-talkers
top 200
sort-by bytes
cache-timeout 1000
All Gigabit interfaces are plugged into trunk ports on swith. There is a traffic in Vlan1, but there is no IP enabled interfaces in that vlan, furthermore arp-proxy and broadcast forwarding explicitly turned off and here what i get:
#sho ip flow top-talkers
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Bytes
Gi0/2 10.131.10.186 Tu1* 10.131.11.255 11 0089 0089 513K
Gi0/2 10.131.11.120 Tu1* 10.131.11.255 11 0089 0089 702
Gi0/2 10.131.10.209 Tu1* 10.131.11.255 11 008A 008A 687
Gi0/2 10.96.37.107 Tu1* 10.96.37.255 11 E8A6 079B 204
Gi0/2 10.96.37.107 Tu1* 10.96.37.255 11 E8A8 079B 204
Gi0/2 10.131.10.120 Tu1* 10.131.11.255 11 E0C5 079B 204
Gi0/2 10.131.10.120 Tu1* 10.131.11.255 11 E0C7 079B 204
8 of 200 top talkers shown. 8 flows processed.
Why the hell broadcast gets forwarded? did i miss something?
IOS is Cisco recommended:
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.2(4)M5, RELEASE SOFTWARE (fc2)
02-06-2014 01:20 AM
It is a bug:
02-06-2014 03:39 AM
Moved up to 15.3(3)M2, problem gone.
