11-27-2013 11:27 PM - edited 03-07-2019 04:49 PM
I have cisco 2951 router having 2mbps(WAN) serial link & internal lan connected to gigabit interface L2-switch(Primary) having approx 150 users,
Every day i have to restart router atleast once a day, somtimes thrice a day.
I have just default route towards wan link.
when router hangs internal lan pings perfectly. but router gateway not . After restart everthing works smoothly.
what will cause this problem ?
11-27-2013 11:32 PM
Hi Harpal,
please check this document:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a0080106fd7.shtml
which IOS u r running on router ??
paste sh version output.
Dont forget to rate helpful posts.
11-28-2013 01:02 AM
If your routers hangs every day, then you should consider upgrading the IOS.
11-28-2013 07:23 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Does your default route direct to next hop IP or to the interface? If the latter, ARP table can fill causing issues. So also if the latter, change to the former.
