Webcast-Catalyst9k
Router IOS Compatability issue
one of my client router i.e.2801 has aRunning IOS as  c2801-advipservicesk9-mz.124-17a.bin.i want to ugrade the IOS of same router as the existing is out of date.
Kindly suggest me which IOS will will suitable to upgrade.
Router Detail.
sh version
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 12.4(17a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 07-Nov-07 14:35 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
INGV_MUMB_HUB1 uptime is 4 days, 2 hours, 54 minutes
System returned to ROM by reload at 15:27:03 IST Sat Jan 18 2014
System image file is "flash:/c2801-advipservicesk9-mz.124-17a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More--                           http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
export@cisco.com.
Cisco 2801 (revision 6.0) with 234496K/27648K bytes of memory.
Processor board ID FHK1049U097
6 FastEthernet interfaces
2 Serial(sync/async) interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
show flash:
-#- --length-- -----date/time------ path
1          780 Dec 24 2011 16:12:16 +05:30 vlan.dat
2       170582 Jan 21 2012 12:51:46 +05:30 crashinfo_20120121-072147
3       170257 Apr 8 2012 17:05:48 +05:30 crashinfo_20120408-113548
4     30816504 Nov 18 2011 15:45:24 +05:30 c2801-advipservicesk9-mz.124-17a.bin
32845824 bytes available (31166464 bytes used)
Rgds//
Wajid
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
c2801-advipservicesk9-mz.124-25g.bin
1 REPLY
119
