Webcast-Catalyst9k
Router ISR G2 3925
hello everybody,
In the link "http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8028d2e5.html" you can see in the Table 3 the number of channel-groups that the VWIC2 support over the ISR G1.
So that, the question is:
how many channel-group the router 3925 can support with a VWIC2-1MFT-E1?  - If you can show me a link I appreciate so much.
Again Tanks,
VIP Super Bronze
Re: Router ISR G2 3925
rene.melendez wrote:
hello everybody,
Again Tanks,
Hello Rene.
The remaining 14 DS-0 channels on the MFT VWIC2 central-office port terminate through the backplane connector of the VWIC2 on the router as a single aggregate channel group. The 14 DS-0 channels are not individually addressable by the router as a channelized service, but can be split into two or more channel groups.
have a look at the data sheet
https://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
Reza
I am not sure Reza, in the document I found clearly mentioned the amount of "channel-groups" support ISR G1, my doubt is about ISR G2 in specific the router 3925.
Anyway, thanks a lot.
921
