Webcast-Catalyst9k
Router memory and IOS
As I look to update my routers I see that the IOS states minimum req for DRAM and FLASH. Getting the flash from the router is pretty easy ... but where in the show ver is the DRAM listed? From the show ver output listed below, is it 28672K/4096K bytes of memory? If so, what do those numbers represent?
Richard
Router#sho ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(31), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 11-Aug-05 17:24 by tinhuang
Image text-base: 0x8000808C, data-base: 0x80A1E318
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-I-M), Version 12.2(31), RELEASE SOFTWARE (fc2)
Router uptime is 1 hour, 25 minutes
System image file is "flash:c2600-i-mz.122-31.bin"
cisco 2620 (MPC860) processor (revision 0x600) with 28672K/4096K bytes of memory
Processor board ID JAD05350BG2 (2599831965)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2142
2 ACCEPTED SOLUTIONS
Re: Router memory and IOS
Hi Richard
DRAM
28672K + 4096K = 32768 KB approx 32 MB RAM
Flash
16384 KB = approx 16 MB
You might also want to set your config-register to the correct value 0x2102. Current config-register skips startup-config
Lejoe
Those numbers represent how the memory on the router is used.
The total amount of installed memory are those two numbers added up. In your case, this router has 32MB, of which 4MB is used as I/O memory.
Marko
CCIE #18427 (SP) // + DE wannabe
My network blog: http://cisco.markom.info
Hi Richard
DRAM
Flash
Lejoe
Marko
Thanks Lejoe and Marko,
Can 2600's be ugraded in memory?
Also ... on some of my other routers I have some unusual numbers for memory that don't seem right such as ...
45056K/4096K ... 49M?
32768K/8192K ... 40M?
127627K/3445K ... 131M?
Those are pretty odd numbers for memory aren't they?
Richard
Richard, in addition to the post to get DRAM and FLASH figures you can simply always devide by 1024.
output example
28672K + 4096K / 1024 = 32 MB DRAM total
Same for flash information
16384 / 1024 = 16MB Flash total
45056K + 4096K / 1024 = 48 MB
32768K + 8192K / 1024 = 40 MB
127627 + 3445K / 1024 = 128 MB
Yes they can all depending what they currently have and what is the maximun they can take.
Go over this specs in this link for upgrading memory hardware in 2600 models.
See table 1
http://www.cisco.com/en/US/docs/routers/access/2600/hardware/installation/notes/2600mem.html#wp92535
290
