Router on a stick problem
daiprice5
Hi all
Im studying for my ccna exam and i'm having problems with a basic router on a stick lab i'm trying to create, i cant ping between hosts on seperate vlans. also im able to ping from the hosts to there gateways and from the router im able to ping the host in vlan 20 but not the host in vlan 10. Here is the config.
hostname LABROUTER
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO3845-MB sn FOC12414ESB
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/0.1
 description LINK TO LABSWITCH
 encapsulation dot1Q 1 native
 ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/1
 ip address dhcp
 duplex auto
 speed auto
 media-type rj45
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
banner motd ^C ************** RESTRICED ACCESS ***************
**************** AUTHORIZED PERSONEL ONLY *********************** ^C
line con 0
 password 7 14101B050314262433
 login
line aux 0
line vty 0 4
 password 7 094B470716151B1D1C
 login
 transport input all
line vty 5 15
 password 7 110E100B1802070313
 login
 transport input all
LABROUTER#sho ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES unset  up                    up
GigabitEthernet0/0.1       192.168.100.1   YES manual up                    up
GigabitEthernet0/0.10      192.168.10.1    YES NVRAM  up                    up
GigabitEthernet0/0.20      192.168.20.1    YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  up                    down
Gateway of last resort is not set
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, GigabitEthernet0/0.10
L        192.168.10.1/32 is directly connected, GigabitEthernet0/0.10
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, GigabitEthernet0/0.20
L        192.168.20.1/32 is directly connected, GigabitEthernet0/0.20
      192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.100.0/24 is directly connected, GigabitEthernet0/0.1
L        192.168.100.1/32 is directly connected, GigabitEthernet0/0.1
Switch Config
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
 switchport access vlan 10
 switchport mode access
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
 switchport access vlan 20
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
 description LINK TO LABROUTER
 switchport mode trunk
 speed 100
 duplex full
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
 ip address 192.168.100.2 255.255.255.0
ip default-gateway 192.168.100.1
ip classless
ip http server
ip sla enable reaction-alerts
1    default                          active    Gi1/0/1, Gi1/0/2
10   LAB_VLAN_10                      active    Fa1/0/1, Fa1/0/2, Fa1/0/3
                                                Fa1/0/4, Fa1/0/5, Fa1/0/6
                                                Fa1/0/7, Fa1/0/8, Fa1/0/9
                                                Fa1/0/10, Fa1/0/11, Fa1/0/12
20   LAB_VLAN_20                      active    Fa1/0/13, Fa1/0/14, Fa1/0/15
                                                Fa1/0/16, Fa1/0/17, Fa1/0/18
                                                Fa1/0/19, Fa1/0/20, Fa1/0/21
                                                Fa1/0/22, Fa1/0/23
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
Vlan1                  192.168.100.2   YES NVRAM  up                    up
FastEthernet1/0/3      unassigned      YES unset  up                    up
FastEthernet1/0/15     unassigned      YES unset  up                    up
The pc address are: host in vlan 10 192.168.10.5 host in vlan 20 192.168.20.5
Any help will be grateful
2 Accepted Solutions
It doesn't, as that is outbound traffic!
When pinging the host, the firewall would block the ping, by default, therefore OP needs to verify this...
Martin
glen.grant
   First thing to try is to hardcode the speed/duplex on your router . you have it hardcoded on the switch side and auto on the router , this will create at the minimum a duplex mismatch and cause speed problems.   Besides that I dont see anything glaring . If you are trying to ping hosts and they are windows machines you must shutoff the firewall function on the hosts or the pings will fail.
12 Replies 12
rpinon
  Just to be sure, can you post the ip configuration  for a host in both vlans? (IP, MASK, Default Gateway)
Ray
The host in vlan 10 : 192.168.10.5
                                  255.255.255.0
                                  192.168.10.1
The host in vlan 20: 192.168.20.5
                                 255.255.255.0
                                 192.168.20.1
Dai
Hmm, if you can ping the gateway for each vlan , that eliminates any firewall settings on PC.
Can you ping 192.168.100.1  from any of the hosts?
Did you add both vlans to the switch and router vlans database?
Martin
firewall? He is able to ping default gateway, so I don't think that is the case
Yes, and as I stated above, it's irrelevant.
Firewall's, by default, allow outbound communication, but block all inbound.
Martin
Thanks for all the help as normal i storm into the deep end and turns out the config is sound it was my firewall on the devices.
Thanks Again
Dai
Mark Jensen
Dont you need to define the vlans 10 and 20 then give them a gateway IP address?
Int vlan 10
ip address x.x.x.x    etc
https://learningnetwork.cisco.com/.../Router%20on%20a%20Stick.pdf
Look at this doc.
 No he does not , the routing is done on the router so no addressing is needed ont he switch other than the single mgmt address he has.
That would be the case for a layer 3 switch but not for router on a stick
glen.grant
