Community Member
router on a stick problem
Hi all, I'm having issues with a simple router on a stick lab. i'm having problems communicating between hosts on seperate vlans. the router is a 3845 and the switch is a 3750.
hostname LABROUTER
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO3845-MB sn FOC12414ESB
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/0.1
 description LINK TO LABSWITCH
 encapsulation dot1Q 1 native
 ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/1
 ip address dhcp
 duplex auto
 speed auto
 media-type rj45
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
banner motd ^C ************** RESTRICED ACCESS ***************
**************** AUTHORIZED PERSONEL ONLY *********************** ^C
line con 0
 password 7 14101B050314262433
 login
line aux 0
line vty 0 4
 password 7 094B470716151B1D1C
 login
 transport input all
line vty 5 15
 password 7 110E100B1802070313
 login
 transport input all
scheduler allocate 20000 1000
end
LABROUTER#sho ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES unset  up                    up
GigabitEthernet0/0.1       192.168.100.1   YES manual up                    up
GigabitEthernet0/0.10      192.168.10.1    YES NVRAM  up                    up
GigabitEthernet0/0.20      192.168.20.1    YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  up                    down
Gateway of last resort is not set
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, GigabitEthernet0/0.10
L        192.168.10.1/32 is directly connected, GigabitEthernet0/0.10
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, GigabitEthernet0/0.20
L        192.168.20.1/32 is directly connected, GigabitEthernet0/0.20
      192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.100.0/24 is directly connected, GigabitEthernet0/0.1
L        192.168.100.1/32 is directly connected, GigabitEthernet0/0.1
Switch Config
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
 switchport access vlan 10
 switchport mode access
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
 switchport access vlan 20
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
 description LINK TO LABROUTER
 switchport mode trunk
 speed 100
 duplex full
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
 ip address 192.168.100.2 255.255.255.0
ip default-gateway 192.168.100.1
ip classless
ip http server
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/2
10   LAB_VLAN_10                      active    Fa1/0/1, Fa1/0/2, Fa1/0/3
                                                Fa1/0/4, Fa1/0/5, Fa1/0/6
                                                Fa1/0/7, Fa1/0/8, Fa1/0/9
                                                Fa1/0/10, Fa1/0/11, Fa1/0/12
20   LAB_VLAN_20                      active    Fa1/0/13, Fa1/0/14, Fa1/0/15
                                                Fa1/0/16, Fa1/0/17, Fa1/0/18
                                                Fa1/0/19, Fa1/0/20, Fa1/0/21
                                                Fa1/0/22, Fa1/0/23
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
here is all the config, also the pc's are setup right, i can ping both the vlan address's from the pc's and i can ping the hosts from the router, but not host to host. any help will be grateful
1 REPLY
Community Member
Please try to ping ping (host
Please try to ping
ping (host.ip.in.vlan10) source 192.168.20.1
ping (host.ip.in.vlan 20) source 192.168.10.1
53
