router question
dhanikonda
Dear sir,
I have cisco 1841 router with HWIC-4ETH module.Now one isp is terminated(1mb)on that router now i taken one nore 2mb for data .Now using HWIC-4eth cord shell i terminate that isp also On that router.It will work or not .If it will work how can i configure the router.
srini
mark.cronin
Level 2
Level 2
Srini
Not sure if this is what you are asking for
interface vlan 10
description ISP-Connection
ip address 10.0.0.1 255.255.255.0
no shut
interface vlan 20
description 2mb-data
ip address 20.0.0.1 255.255.255.0
vlan 10
vlan 20
interface ethernet 0/0/0
switchport
switchport access vlan 10
no shut
interface ethernet 0/0/1
switchport
switchport access vlan 20
no shut
It depends on your requirements.
Are you going to use the second link for
Internet Access or for only setting up VPN's ?
A brief on your setup and your requirements will help us to guide you better.
Amit Singh
Hi Srini,
It depends on what services you are running on the routers. If you dont have much servcies enabled on the routers like Security IOS firewall and VPN services, wireless services, then it may work as the more you enable the services the more routers gets loaded. For the configuration part Please see the configs provided by the poster above.
-amit singh
