Community Member
router rebooted
Last night my cisco 2800 router rebooted/restarted automatically. Why does this happen.. how do I check the exact reason of rebooting. pls. tell the command to trace the reason.
Re: router rebooted
Show version will give you the reason what caused the reboot.
Mahmood
Community Member
Re: router rebooted
Sorry , but thr is no reason in show version.
Re: router rebooted
Can you please post the show version.
BR,
Mohammed Mahmoud.
Community Member
Re: router rebooted
here us sh version
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.3(14)T5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 24-Oct-05 21:43 by kellythw
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Sugal_KB uptime is 12 minutes
System restarted at 19:15:59 utc Fri Jun 29 2007
System image file is "flash:c2800nm-advsecurityk9-mz.123-14.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FHK0950F11R
2 Gigabit Ethernet interfaces
31 Serial interfaces
4 Serial(sync/async) interfaces
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125184K bytes of ATA CompactFlash (Read/Write)
Re: router rebooted
This statement "System returned to ROM by power-on" indicates that it was a power issue, please check that the router power is stable and that the UPS is running fine if you are using one.
HTH,
Mohammed Mahmoud.
143
