07-02-2014 08:26 AM - edited 03-07-2019 07:54 PM
I hope you can help in answering this query. WE have a site with the following setup:
The Router has a single ADSL link with a single Public IP address, its connected to the ASA on the 172.16.0.0/24 network.
The ASA is connected to the Local LAN on the 192.168.95.0/24 network. We do have servers and printers doing NAT on the ASA. There is also a primary link where on site where all of this is working normally. The above setup is for the fail over link.
How would I setup the NAT on the ASA and on the router, I did not wish to do a double NAT on the ASA and then the Router as well.
Is there a better solution to set this up.
Many thanks
Upen Desai
07-02-2014 10:18 AM
Hi Upen,
You can do NAT once in the router..... all you need is the routing in the ISP router towards your private network.....
for eg if you have web server, smtp server & ftp server in your lan then
ip nat inside source static tcp <private ip> 21 <public ip> 21
ip nat inside source static tcp <private ip> 25 <public ip> 25
ip nat inside source static tcp <private ip> 80 <public ip> 80
Karthik
07-02-2014 10:40 AM
Hello Karthik
Thank you for coming back to me. As mentioned in the original question we have two ISPs but I am trying to set this up on the backup link.
When the primary link fails and the ASA fails over to the ADSL link do I just have the default route to the router, send all the LAN traffic straight to the router via the ASA and let the router do the NAT.
