Community Member
Routing Experts please help with below LAN routing issue with NAT
Hello Experts,
I have a weird situation and requirement.
The existing setup is -
We have email/ticketing server hosted in the LAN which is reachable on the publicly NAT'ed IP with respective port numbers of 89 & 443. We have LAN & servers on the same subnet. The internet is with public DHCP IP assigned by ISP (/29). We use linksys router GUI for NAT settings (attached).We are using the same public IP for the server NAT & user NAT.
We tried to refresh our network by separating the subnets for LAN users & servers. We used the Cisco 3845 router to create sub-interfaces in the LAN and configure respective subnets. Now both user subnet and server subnet are connecting to the Internet with same public IP (static NAT for servers & dynamic for users). We can connect to the server IP from the Internet and it resolves fine. However user LAN subnet cannot connect to the server if we try the URL. Users can access the Internet fine.
Please find attached short diagram and below configuration and please give your inputs to solve this.
Cisco 3845 router
access-list 1 permit 10.155.60.0 0.0.0.255
access-list 2 permit 10.155.61.0 0.0.0.255
access-list 3 permit 10.155.62.0 0.0.0.255
ip nat inside source list 1 int g0/0 overload
ip nat inside source list 2 int g0/0 overload
ip nat inside source list 3 int g0/0 overload
int g0/0
ip add 8.8.8.8 255.255.255.248
ip nat outside
no shut
int g0/1
description Trunk-to-Switch
no shut
int g0/1.60
description User vlan
ip add 10.155.60.1 255.255.255.0
encapsulation dot1q 60
ip nat inside
int g0/1.62
description Server vlan
ip add 10.155.62.1 255.255.255.0
encapsulation dot1q 62
ip nat inside
exit
aaa new-model
aaa authentication login default local
aaa authentication login vpn_xauth_ml_1 local
aaa authentication login sslvpn local
aaa authorization network vpn_group_ml_1 local
aaa session-id common
acl 120
max-users 10
exit
!access-list 120 remark ==[Cisco VPN Users]==
access-list 120 permit ip any host 192.168.0.10
access-list 120 permit ip any host 192.168.0.11
access-list 120 permit ip any host 192.168.0.12
access-list 120 permit ip any host 192.168.0.13
access-list 120 permit ip any host 192.168.0.14
access-list 120 permit ip any host 192.168.0.15
access-list 120 permit ip any host 192.168.0.16
access-list 120 permit ip any host 192.168.0.17
access-list 120 permit ip any host 192.168.0.18
access-list 120 permit ip any host 192.168.0.19
no access-list 100
access-list 100 remark [Deny NAT for VPN Clients]=-
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.10
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.11
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.12
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.13
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.14
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.15
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.16
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.17
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.18
access-list 100 deny ip 192.168.0.0 0.0.0.255 host 192.168.0.19
access-list 100 remark -=[Internet NAT Service]=-
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
exit
ip nat inside source static tcp 10.155.62.55 21 8.8.8.8 21
ip nat inside source static tcp 10.155.62.55 88 8.8.8.8 88
ip nat inside source static udp 10.155.62.55 88 8.8.8.8 88
ip nat inside source static tcp 10.155.62.84 3389 8.8.8.8 3389
ip nat inside source static udp 10.155.62.84 3389 8.8.8.8 3389
ip nat inside source static tcp 10.155.62.98 80 8.8.8.8 80
ip nat inside source static udp 10.155.62.98 80 8.8.8.8 80
ip nat inside source static tcp 10.155.62.98 443 8.8.8.8 443
ip nat inside source static udp 10.155.62.98 443 8.8.8.8 443
ip nat inside source static tcp 10.155.62.98 25 8.8.8.8 25
ip nat inside source static udp 10.155.62.98 25 8.8.8.8 25
ip nat inside source static tcp 10.155.62.84 8080 8.8.8.8 89
ip nat inside source static udp 10.155.62.84 8080 8.8.8.8 89
ip nat inside source static tcp 10.155.62.84 9005 8.8.8.8 9005
ip nat inside source static udp 10.155.62.84 9005 8.8.8.8 9005
ip nat inside source static tcp 10.155.62.84 135 8.8.8.8 135
ip nat inside source static udp 10.155.62.84 135 8.8.8.8 135
ip nat inside source static tcp 10.155.62.84 139 8.8.8.8 139
ip nat inside source static udp 10.155.62.84 139 8.8.8.8 139
ip nat inside source static tcp 10.155.62.84 445 8.8.8.8 445
ip nat inside source static udp 10.155.62.84 445 8.8.8.8 445
ip nat inside source static tcp 10.155.62.84 90 8.8.8.8 465
ip nat inside source static udp 10.155.62.84 90 8.8.8.8 465
ip nat inside source static tcp 10.155.62.143 3381 8.8.8.8 3381
ip nat inside source static udp 10.155.62.143 3381 8.8.8.8 3381
ip nat inside source static tcp 10.155.62.46 8081 8.8.8.8 91
ip nat inside source static udp 10.155.62.46 8081 8.8.8.8 91
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/cme-gui-7.1.0.1
file privilege 0
telephony-service
dn-webedit
time-webedit
transport input ssh
line con 0
line vty 0 15
login local
ntp server ntp.first2know.net
clock timezone gmt 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
ntp update-calendar
ntp master
Cisco 3750 Config;
vlan 60
name User
vlan 61
name Voice
vlan 62
name Server
exit
interface g1/0/1
description Trunk-to-Router
switchport mode trunk
spanning-tree portfast trunk
interface vlan 60
description User Vlan
ip add 10.155.60.2 255.255.255.0
interface vlan 61
description Voice Vlan
ip add 10.155.61.2 255.255.255.0
interface vlan 62
description Server Vlan
ip add 10.155.62.2 255.255.255.0
service dhcp
ip dhcp pool Users
network 10.155.60.0 255.255.255.0
default-router 10.155.60.1
dns server 4.2.2.2
ip dhcp pool Voice
network 10.155.61.0 255.255.255.0
dns server 4.2.2.2
exit
ip dhcp excluded-address 10.155.60.1 10.155.60.2 10.155.60.3
ip dhcp excluded-address 10.155.61.1 10.155.61.2
interface range g1/0/2 - 1/0/21
switchport mode access
switchport access vlan 60
switchport access vlan 61
exit
exit
interface range g1/0/22 - 1/0/26
switchport access vlan 62
exit
Deepak
Everyone's tags (4)
92
