10-10-2017 05:18 AM - edited 03-08-2019 12:19 PM
We have existing network of core switch and one main router. All vlans traffic was going out from main router. Now, we have decided to isolate guest network from corporate network.
So, I connected secondary router with same core switch port. Now, i want to route guest vlan traffic to that secondary router and rest all vlan continue to router from primary router.
Can anyone let me know that how to do this. Thanks
Solved! Go to Solution.
10-10-2017 06:03 AM
Hello
you can also have the guest L3 on this new rtr and just have L2 on your Lan towards it in that case you are just utilising the physical infrastructure-But given the choice vrf -lite would be the most applicable
res
paul
10-10-2017 09:30 AM
The important parts of configuring PBR include these steps:
- configure an access list that identifies the traffic that will need the special routing of PBR.
- configure a route map that will use the access list to identify traffic and will set the next hop for the traffic that matches the ACL.
- apply the route map on the interface which receives the traffic that will need the special routing of PBR.
Since we do not know anything specific about your environment, assume these parameters to create an example for the PBR. Guest uses network 192.168.200.0. Guest is on vlan 200. The next hop address for the new router is 1.2.3.4. Something like this is what you need to add to your config:
access-list 100 permit ip 192.168.200.0 0.0.0.255 any
route-map PBR_guest permit 10
match ip address 10
set ip next-hop 1.2.3.4
interface vlan 200
ip policy route-map PBR_guest
There are a number of other things that could be used in PBR but this represents the basics of what you would need.
Rick
10-10-2017 05:34 AM
10-10-2017 06:08 AM
We do not know what kind of switch is the core switch so we do not know what its capabilities are. If it supports VRFs (and especially if it supports VRF Lite) then that might be the optimum way to separate the guest traffic and send it through the second router. The other option to consider would be to use Policy Based Routing to send traffic from the Guest vlan to the second router.
Rick
10-10-2017 06:23 AM
Core switch is 3750 with advipservices IOS. How to configure VRF lite or PBR. Can you please let me know. Thanks
10-10-2017 09:30 AM
match ip address 10
interface vlan 200
Rick
10-10-2017 09:41 PM
Mr. Rick,
Thanks for your reply. I have followed as you suggested below and on 2nd router i configured IP on LAN interface 1.1.1.2/30 and in switchport 1.1.1.1/30.
2nd router WAN port is also configured with public IP. Internet is working from 2nd router.
Now, when i ping 8.8.8.8 from switch keeping source as vlan 200 it does ping. Switch can ping router LAN interface 1.1.1.2. 2nd router is 1841. There are 2 router in 2nd router
ip route 0.0.0.0.0 0.0.0.0 <public IP>
ip route 192.168.200.0 255.255.255.0 1.1.1.1
10-11-2017 08:12 AM
Thank you for the additional information. Can you clarify how the switchport is configured? Is it configured as a routed port (no switchport), or is it in a vlan? If in a vlan then which vlan is it in?
Also I am not clear in your response whether you have configured PBR on the switch. Can you clarify this?
Rick
10-11-2017 10:02 PM
switch port is having IP address 1.1.1.1 255.255.255.252 and "no switchport" command.
Vlan interface is having IP address 192.168.200.254 255.255.255.0 and ip poloicy "route-map"command.
one ACL matching intresting traffic which is 192.168.200.0/24
one route map having match & set commands. matching ACL and setting next hop 1.1.1.2.
In router, interface is configured with 1.1.1.2 255.255.255.252 & ip nat inside
other interface is having public IP address.
2 ip routes, one default route to public IP & other is 192.168.200.0/24 next hop 1.1.1.1
Thanks.
10-12-2017 08:43 AM
Thank you for the additional information. What you tell of the configuration sounds right. Is the PBR working?
Rick
10-10-2017 06:21 AM
Guest vlan traffic shouldnt coomunicate with other vlan network. Secondary router is used with another ISP.
10-10-2017 06:03 AM
Hello
res
paul
10-10-2017 06:29 AM
in my core switch guest vlan is created before. Right now guest vlan is passing from core switch to primary link using firewall. I have one default router toward firewall from switch.
I have connected one switchport of core switch with secondary router. Thanks
