Routing IP
I know this is basic stuff but I can't find where I am having a problem routing from a 3750 switch through the router to the Internet. Could someone look at the config and see where I have screwed up?
I have no access list that would stop it.
I can ping from a host on the 172.16.100.0 network to the 10.10.0.0 network but not to the outside world.
Switch 3750:
clock summer-time UTC recurring
system mtu routing 1500
vtp domain LeeAerospace
vtp mode transparent
udld aggressive
ip subnet-zero
ip routing
ip domain-name leeaerospace.local
ip name-server 10.10.21.1
ip dhcp smart-relay
ip dhcp relay information trust-all
ip dhcp excluded-address 172.16.100.0 172.16.100.20
ip dhcp pool Computers
network 172.16.100.0 255.255.255.0
default-router 172.16.100.1
option 150 ip 10.10.11.10
dns-server 10.10.21.3
netbios-name-server 10.10.21.1
spanning-tree mode rapid-pvst
spanning-tree loopguard default
vlan internal allocation policy ascending
vlan 100,200
interface FastEthernet1/0/11
switchport access vlan 100
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust cos
auto qos voip trust
spanning-tree portfast
interface GigabitEthernet1/0/2
no switchport
ip address 172.16.2.2 255.255.255.0
ip helper-address 10.10.21.3
queue-set 2
priority-queue out
mls qos trust dscp
auto qos voip trust
macro description cisco-switch | cisco-switch
spanning-tree link-type point-to-point
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address 172.16.100.1 255.255.255.0
ip helper-address 172.16.10.20
interface Vlan200
ip address 172.16.200.1 255.255.255.0
interface Vlan254
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.2.1
Router:
Here is the static routes configured
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.100.254
ip route 172.16.0.0 255.255.0.0 172.16.2.2
Here is the Show Ip Routes
Gateway of last resort is 192.168.100.254 to network 0.0.0.0
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
S 172.16.0.0/16 [1/0] via 172.16.2.2
C 172.16.2.0/24 is directly connected, GigabitEthernet1/0
10.0.0.0/24 is subnetted, 7 subnets
C 10.10.10.0 is directly connected, GigabitEthernet0/0.10
C 10.10.11.0 is directly connected, GigabitEthernet0/0.11
C 10.10.20.0 is directly connected, GigabitEthernet0/0.20
C 10.10.21.0 is directly connected, GigabitEthernet0/0.21
C 10.10.22.0 is directly connected, GigabitEthernet0/0.22
C 10.10.23.0 is directly connected, GigabitEthernet0/0.23
C 10.10.254.0 is directly connected, GigabitEthernet0/0.254
C 192.168.1.0/24 is directly connected, GigabitEthernet0/0.50
C 192.168.100.0/24 is directly connected, GigabitEthernet0/1
S* 0.0.0.0/0 [1/0] via 192.168.100.254
Re: Routing IP
Your default route on the router is set to 192.168.100.254. That tells me you have another router you are going through to get to the Internet. Does that router have a route back to the 172.16.0.0 / 16 network? If you can get on that router try and ping some of the networks on the inside. If you cannot then it is a route that needs to be added on that router.
Re: Routing IP
Very perceptive, that was exactly where the problem was I found it right after I posted. Thanks for your reply.
Re: Routing IP
Never Mind the problem was in a different Router.
128
