Routing issue between VLAN's.
alpineclubIT
Here is the scenario. I have a public and a private VLAN setup (public 192.168.2.x, private 192.168.1.x) on purpose I don't want people to be able to hop directly between Vlan 2 and Vlan 1 which is fine, BUT the web server for the organization is located on VLAN1, which I want to be able to be accessed from VLAN2. All that happens now, is that the request goes from VLAN2 to the DNS server (external) and then the request come back to the router, and the router pops up the login page only, it doesn't seem to use the NAT entry for the web server.
This seems like it should be something simple, but I can't seem to find an entry or ACL to create to allow this to happen.
The router is an 871.
Thanks in advance.
Jeff.
7 Replies 7
cadet alain
post your config.
Regards.
Alain
sleepyshark
That's an asymmetrical route, which Cisco is WELL known for specifically not allowing.  Their philosophy is that you need to route between interfaces to keep things kosher, not route to your external side, then back in.  What you're trying to do can be easily fixed by creating an internal DNS server and pointing your www.domainname.com to the internal IP address on VLAN1...
FYI: Most high-end routers/firewalls don't like asymmetrical routes... It's a HUGE pain, but it is best practice not to have them.
Sean Brown (sean@sleepyshark.com)
voice: 212.760.1700 x7001
Wanna learn more about me? Check out my bio
Follow me on LinkedIn
Sean,
I understand what you mean, BUT my DNS server (which I do have a  local one) is on the 192.168.0.x network, which is implied that you cannot cross from 192.168.2.x to 192.168.1.x should I just create an entry for traffic on port 80 to allow access between, but then I don't think DNS will work either, as that uses a different access method .?
Any further assistance of course is greatly appreciated.
Jeff.
Can you either post your config or a diagram of your network... Specifically, I need to know what VLAN's are associated to which subnets and which ways traffic SHOULD go and where it shouldn't go...
Hi Sean,
Attached is config (useless entries removed).
Traffice from VLAN2 should ONLY flow to VLAN 1 for webtraffic on ports 80 and 443.
I have a DNS server at 192.168.0.102, which has entries on the 192.168.0.x subnet, which works fine on that subnet for all computer attached to VLAN1.
Jeff.
Using 18897 out of 131072 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot system flash c870-adventerprisek9-mz.123-8.YI3.bin
boot-end-marker
logging buffered 51200 debugging
enable secret 5 $1$OC/j$uR69snOYl8cqu4Y5CUUCr0
username accadmin privilege 15 secret 5 $1$hMT3$yonH5bVbG0jrycc/PkxKQ0
clock timezone MDT -7
clock summer-time MDT date Apr 6 2003 2:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip dhcp excluded-address 192.168.0.176 192.168.0.254
ip dhcp excluded-address 192.168.0.1 192.168.0.149
ip dhcp excluded-address 192.168.3.201 192.168.3.254
ip dhcp excluded-address 192.168.3.1 192.168.3.124
ip dhcp pool sdm-pool1
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   domain-name
   dns-server 192.168.0.102
   lease infinite
ip dhcp pool sdm-pool2
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   lease 0 3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Vlan2
ip address 192.168.3.1 255.255.255.0
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 remark INSIDE_IF=Vlan3
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.3.0 0.0.0.255
access-list 101 remark SDM_ACL Category=1
access-list 101 remark Vlan1-Vlan2
access-list 101 deny   ip 192.168.0.0 0.0.0.255 192.168.3.0 0.0.0.255 log
access-list 101 remark Vlan1-Any
access-list 101 permit ip 192.168.0.0 0.0.0.255 any log
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any any eq bootpc
access-list 103 permit udp any any eq bootps
access-list 103 permit tcp any any eq domain
access-list 103 permit udp any any eq domain
access-list 103 remark Vlan2-Vlan1
access-list 103 deny   ip 192.168.3.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 103 permit ip 192.168.3.0 0.0.0.255 any
So you want traffice from VLAN2 should only access to VLAN1 for webtraffic on ports 80 and 443.
You can put access-lists accordintly like below...
ip access-li ex Vlan1
permit tcp 192.168.0.0 0.0.0.255 192.168.3.0 0.0.0.255 eq 80
permit tcp 192.168.0.0 0.0.0.255 192.168.3.0 0.0.0.255 eq 443
deny any 192.168.3.0 0.0.0.255
interface Vlan1
ip access-group Vlan1 in
Please rate the helpfull posts.
Naidu.
Hi Jeff -
If all of your traffic is on VLAN1, the above poster's ACL will allow ONLY 80/443 traffic from VLAN1 -> VLAN2.... From there, simply add an A record to your DNS server 192.168.0.102 for www.sitename.com -> webserver IP on VLAN2 and any user on VLAN1 will resolve www.sitename.com and direct traffic to VLAN2, not asymmetrically routing.
This is the easiet way to accomplish what you want to do without making major modifications to your infrastrucutre.
