Webcast-Catalyst9k
Routing Issue I Believe (missing something)
I've managed to get the 2811 router T1 and associated serials up and running and I have the 2960G switch up and running. I connect a PC to the switch port of choice and recieve the proper IP/Subnet Mask/Default Gateway/and all DNS information. However I cannot see the internet,cannot ping known public servers. I can ping the Default Gateway.
I can access both device from an outside network (say at home) via both Http and telnet. Hence I believe i am missing something very fundamental. After staring at files and printouts for 12+ hours I do believe someone may look at the 2 config files and quickly find my error.
Any input is appreciated. I will rate post with solution.
Thank you
Greg
files downloadable
Green
Re: Routing Issue I Believe (missing something)
Ip route 0.0.0.0 0.0.0.0
I don't think I saw a default route in your router config (I only had a little time to look ....)
Good Luck
Scott
ip route 0.0.0.0 0.0.0.0 10.60.9.61
it's there, it's the one they gave me to setup the T1 Frame-Relay.
I got 6 static IP addresses
72.242.113.65~70
they said:
Public IP Block: 72.242.113.64
Subnet Mask: 255.255.255.248
First Useable: 72.242.113.65
Last Useable: 72.242.113.70
IP On Cisco 2811 Router (Customer Gateway): 72.242.113.65
Notes: unusable address 72.242.113.64 is Network ID 72.242.113.65 is Your Gateway 72.242.113.71 is Broadcast
think i did everything right but so much for thinking my brain is mush at the moment.
Greg
Gold
I suspect it a nat issue.
It depends on what you are doing with fa 0/1.
It is marked as a firewall but as far as routing I can't see it used.
The traffic appears to go from the various subinterfaces to the serial interface.
The NAT function only occurs on a inside to outside or outside to inside traffic flow. You traffic is going from inside to a undefined interface so nat does not run.
You can make this work by making your serial port a outside interface. It will still use the fa 0/1 address to do the nat.
I would recommend you change the nat statement to use a pool with just that one address if you wish rather than use the interface name. It just makes thing confusing.
146
