04-18-2008 07:01 AM - edited 03-05-2019 10:28 PM
This is driving me nuts. I'm sure the problem is starring me in the face but i need a little help.
I am working on a BSCI lab for multicasting but I have a routing problem.
Here is the setup.
R1 < - > R2 < - > SW1
R1 s1/0 connects to R2 s1/0 via serial.
R2 fa0/0 connects to a switch SW1 f1/1 via fastethernet.
SW1 has VLAN20 in its vlan database.
SW1 fa1/1 has switchport mode access, and switchport access vlan20 applied.
*SW1 has "ip default-gateway 172.16.20.2" applied
the serial link has IP of 172.16.102.0/29 with R1 on .1 and R2 on .2
The fastethernet link has an IP of 172.16.20.0/24 with R2 fa0/0 on .2
VLAN20 on SW1 has the ip of 172.16.20.4
EIGRP is setup on R1 and R2 with the following setup:
Router EIGRP 1
Network 172.16.0.0
R1 can not ping 172.16.20.4
R1 has a route to 172.16.20.0/24 via R2's serial link.
my brain(and the lab i am working on) says this should work but it doesnt.
any thoughts?
any help is greatly appreciated.
Eric
*crap, sorry had some incomplete information
Solved! Go to Solution.
04-18-2008 11:04 AM
Nice one Sundar...
04-18-2008 11:08 AM
you guys rock, thanks so much for the help today.
who wants the rating?
SW1#ping 172.16.102.1
Sending 5, 100-byte ICMP Echos to 172.16.102.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/320/1068 ms
SW1#
R1#ping 172.16.20.4
Sending 5, 100-byte ICMP Echos to 172.16.20.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/204/504 ms
R1#
:) <--- this is me, really happy.
e-
04-18-2008 11:09 AM
Eric
Glad you got it working, rating belongs to Sundar.
Jon
04-18-2008 11:11 AM
Eric
Glad to hear it's working :-)
Honestly, you should rate both as Jon did a big chunk of the work and I only gave the finishing touches.
Sundar
04-18-2008 11:14 AM
Jon,
Thanks for the rating.
It has put me real close to the Green star :-)
LOL
Sundar
04-18-2008 12:01 PM
Hi Sundar,
Congratulations on the Green star ;)
BR,
Mohammed Mahmoud.
04-18-2008 12:05 PM
Looks like you've got it now :-) Like to add my congratulations to Mohammed's.
Jon
