Routing Lab Question, cant ping vlan ip
This is driving me nuts. I'm sure the problem is starring me in the face but i need a little help.
I am working on a BSCI lab for multicasting but I have a routing problem.
Here is the setup.
R1 < - > R2 < - > SW1
R1 s1/0 connects to R2 s1/0 via serial.
R2 fa0/0 connects to a switch SW1 f1/1 via fastethernet.
SW1 has VLAN20 in its vlan database.
SW1 fa1/1 has switchport mode access, and switchport access vlan20 applied.
*SW1 has "ip default-gateway 172.16.20.2" applied
the serial link has IP of 172.16.102.0/29 with R1 on .1 and R2 on .2
The fastethernet link has an IP of 172.16.20.0/24 with R2 fa0/0 on .2
VLAN20 on SW1 has the ip of 172.16.20.4
EIGRP is setup on R1 and R2 with the following setup:
Router EIGRP 1
Network 172.16.0.0
R1 can not ping 172.16.20.4
R1 has a route to 172.16.20.0/24 via R2's serial link.
my brain(and the lab i am working on) says this should work but it doesnt.
any thoughts?
any help is greatly appreciated.
Eric
*crap, sorry had some incomplete information
1 ACCEPTED SOLUTION
Re: Routing Lab Question, cant ping vlan ip
Jon
I am thinking ip routing may be enabled in the switch, which would make ip default-gateway command irrelevant.
Eric
Can you post 'show ip route' from the switch.
Sundar
Hall of Fame Super Blue
Eric
Is the switch a layer 2 or layer 3 switch. If layer 2 have you set the "ip default-gateway" to point 172.16.20.2.
Also can you confirm the vlan interface 20 is actually up ie.
sh ip int br
Jon
sorry, i forgot to include that bit. I just edited it as you posted your reply. Sorry about that.
And yes, VLAN20 shows up and up. and so does fa1/1
switch is a 3660 with a NM-16esw blade. layer 2
duplicate, sorry not my day
Can you
1) ping 172.16.20.4 from 172.16.20.2
2) ping 172.16.20.2 from 172.16.102.1
3) ping 172.16.102.1 from 172.16.20.2
Can you post "sh ip ro" from R1 and R2.
Jon
using extended pings...
YES
YES
YES
Sure, i took the code legend out.
R1#show ip route
Gateway of last resort is not set
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
D 172.16.20.0/24 [90/20514560] via 172.16.102.2, 00:07:35, Serial1/0
C 172.16.102.0/29 is directly connected, Serial1/0
R2#show ip route
C 172.16.20.0/24 is directly connected, FastEthernet0/0
thanks Jon, i didnt expect the 3rd ping to work.
e-
Could it be maybe an issue with discontiguous subnets? Since the serial link is 172.16.102.0 and the fastether is 172.16.20.0...
dont know, i am grabbing at straws.
e-
Eric
No i don't think it's discontiguos subnets. Coudl you post the full configs for all devices. I suspect it is an issue with the switch.
Jon
Sure thing, here you go.
R1
version 12.3
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
ip audit po max-events 100
interface Serial1/0
bandwidth 128
ip address 172.16.102.1 255.255.255.248
serial restart-delay 0
clock rate 128000
router eigrp 1
network 172.16.0.0
auto-summary
ip classless
no ip http server
no ip http secure-server
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
R2
version 12.3
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
interface FastEthernet0/0
ip address 172.16.20.2 255.255.255.0
duplex full
interface Serial1/0
bandwidth 128
ip address 172.16.102.2 255.255.255.248
router eigrp 1
network 172.16.0.0
auto-summary
ip classless
no ip http server
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
SW1#
version 12.4
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface FastEthernet1/1
switchport access vlan 20
interface Vlan1
no ip address
interface Vlan20
ip address 172.16.20.4 255.255.255.0
ip http server
ip forward-protocol nd
control-plane
line con 0
line aux 0
line vty 0 4
login
end
SW1#vlan database
SW1(vlan)#show
VLAN ISL Id: 1
Media Type: Ethernet
VLAN 802.10 Id: 100001
State: Operational
MTU: 1500
Translational Bridged VLAN: 1002
Translational Bridged VLAN: 1003
VLAN ISL Id: 20
VLAN 802.10 Id: 100020
State: Operational
MTU: 1500
Eric
I have just labbed this up with 2 routers (2621XM's) and a switch (3560) and it works fine ie. i have full connectivity.
Can you post "sh cdp neigh" from the switch.
Not sure what is wrong here as configs look good.
Jon
Jon
Eric
Sundar
Sundar
I think you may well be right. I didn't think the NM-16esw module in a 3660 could do L3 routing.
If it fixes it i'll rate :-)
Edit - just looked it up and it can.
Jon
DOH!
SW1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
172.16.0.0/24 is subnetted, 1 subnets
C 172.16.20.0 is directly connected, Vlan20
SW1#
so... issue a "no ip routing" on SW1?
e-
Yep
Nice one Sundar...
you guys rock, thanks so much for the help today.
who wants the rating?
SW1#ping 172.16.102.1
Sending 5, 100-byte ICMP Echos to 172.16.102.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/320/1068 ms
SW1#
R1#ping 172.16.20.4
Sending 5, 100-byte ICMP Echos to 172.16.20.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/204/504 ms
R1#
:) <--- this is me, really happy.
e-
Eric
Glad you got it working, rating belongs to Sundar.
Jon
Eric
Glad to hear it's working :-)
Honestly, you should rate both as Jon did a big chunk of the work and I only gave the finishing touches.
Sundar
Jon,
Thanks for the rating.
It has put me real close to the Green star :-)
LOL
Sundar
Hi Sundar,
Congratulations on the Green star ;)
BR,
Mohammed Mahmoud.
Looks like you've got it now :-) Like to add my congratulations to Mohammed's.
Jon
298
