Routing problem with vpn
Hi all
having a few problems with getting some routing going
first router (cisco 881) is on the 192.168.99.x range (network 1) and is connect physically to the second router via setting up seperate port on second router and uses a ip address on the 192.168.99.x range, the first router (cisco 881) uses using static routes to get to to the second router (cisco 881 also)on the 192.168.40.x range (network 2). this routing works perfectly
now heres is the spanner
i would like to access network 3 from network 1
network 3 on the range 192.168.41.x (cisco srp521w) is connected to network 2 (192.168.40.x) via a site to site VPN
how do i go about setting this up, or is this not possible
Everyone's tags (1)
272
