Routing Traffic in ASA Failover Scenario
Hello, all -
We're in the process of swapping in a new pair of ASA5520s and Catalyst 3750s to support two separate business units. We want Firewall A and Switch A to handle traffic for Org A (VLAN 100). Similarly, firewall B and Switch B should handle traffic for Org B (VLAN200). But we want to be able to fail traffic over in case of firewall or switch failure. Traffic between the two Orgs is being routed at the switch level.
The ASAs are set up for Active/Active failover, and we have VLANs set up as follows:
Org A VLAN 100 (.100 subnet)
Org B VLAN 200 (.200 subnet)
Switch A uplink subnet (.1)
Switch B uplink subnet (.2)
The uplink interface on each switch is currently a routed port with a static address on the uplink subnet.  This works fine in a normal state.  However, when we fail over one of the firewall contexts to the other chassis, this results in the inability to route internal traffic because the internal interface is now physically connected to a different switch with a different IP port address (obvious in hindsight).
The question is, rather than a routed port, what would be the proper way to handle traffic between the switches and firewalls in a failover scenario?
If I make the uplink ports into trunks, won't this cause all packets destined for either firewall to hit both both?  Seems like that's not the way to go either?
For more information, a concept diagram and the ASA and catalyst configs as they are currently are here:
ASA Context 1 (Org A)
interface Inside
nameif Inside
security-level 20
ip address 192.168.1.1 255.255.255.0 standby 192.168.1.2
interface Outside
nameif Outside
security-level 40
ip address x.x.246.131 255.255.255.0 standby x.x.246.133
interface Management0/0
nameif management
security-level 100
ip address 192.168.4.1 255.255.255.0 standby 192.168.4.3
management-only
access-list Inside_access_in extended permit ip any any
pager lines 24
logging asdm informational
mtu Inside 1500
mtu Outside 1500
mtu management 1500
no monitor-interface Outside
no monitor-interface management
icmp unreachable rate-limit 1 burst-size 1
asdm location 192.168.200.0 255.255.252.0 management
asdm location 192.168.100.0 255.255.252.0 management
asdm location 10.0.0.2 255.255.255.255 management
no asdm history enable
arp timeout 14400
nat (management) 101 0.0.0.0 0.0.0.0
route Outside 0.0.0.0 0.0.0.0 x.x.246.1 1
route Inside 192.168.2.0 255.255.255.0 192.168.1.3 1    --Route traffic back to switch A for other VLANS
route Inside 192.168.100.0 255.255.252.0 192.168.1.3 1
route Inside 192.168.200.0 255.255.252.0 192.168.1.3 1
ASA Context 2 (Org B)
interface Inside
nameif Inside
security-level 20
ip address 192.168.2.1 255.255.255.0 standby 192.168.2.2
interface Outside
nameif Outside
security-level 40
ip address x.x.246.132 255.255.255.0 standby x.x.246.134
nameif Management
security-level 100
ip address 192.168.4.2 255.255.255.0
management-only
pager lines 24
mtu Outside 1500
mtu Inside 1500
mtu Management 1500
arp timeout 14400
route Inside 192.168.1.0 255.255.255.0 192.168.2.3 1     --Route traffic back to switch B for other VLANS
route Inside 192.168.100.0 255.255.252.0 192.168.2.3 1
route Inside 192.168.200.0 255.255.252.0 192.168.2.3 1
Catalyst 3570 Switch 1 (Org A)
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
no switchport
ip address 192.168.1.3 255.255.255.0     --Routed port.  This IP does not work in ASA failover scenario.
interface GigabitEthernet1/0/5            --Example member port for Org A client VLAN
switchport access vlan 100
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/23          --Trunking between switches for internal VLANs
switchport trunk encapsulation isl
switchport trunk allowed vlan 1,2,4
switchport mode trunk
interface GigabitEthernet1/0/24
switchport trunk allowed vlan 20,100,200
interface Vlan1
no ip address
shutdown
interface Vlan2
no ip address
shutdown
interface Vlan4
interface Vlan20
ip address 192.168.20.1 255.255.252.0
interface Vlan100
ip address 192.168.100.1 255.255.252.0
interface Vlan200
ip address 192.168.200.2 255.255.252.0
router rip
network 192.168.1.0
network 192.168.2.0
network 192.168.4.0
network 192.168.20.0
network 192.168.100.0
network 192.168.200.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 192.168.2.0 255.255.255.0 Vlan200
Catalyst 3570 Switch 2 (Org B)
ip routing
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
interface GigabitEthernet2/0/1
no switchport
ip address 192.168.2.3 255.255.255.0     --Routed port.  This IP does not work in ASA failover scenario.
interface GigabitEthernet2/0/5            --Example member port for Org B client VLAN
switchport access vlan 200
interface GigabitEthernet2/0/23          --Trunking between switches for internal VLANs
interface GigabitEthernet2/0/24
interface Vlan1
no ip address
shutdown
interface Vlan2
no ip address
shutdown
interface Vlan4
interface Vlan20
ip address 192.168.20.2 255.255.252.0
interface Vlan100
ip address 192.168.100.2 255.255.252.0
interface Vlan200
ip address 192.168.200.1 255.255.252.0
ip default-gateway 192.168.2.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip route 192.168.1.0 255.255.255.0 Vlan100
Everyone's tags (2)
658
