Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
RPS 2300 and 3750
We were advised to get an RPS2300 to use to keep our switches running while changing out the main power connections to our switches. However we are now finding that the 3750 still needs to reboot to activate the internal power supply. Is there any way to force the switch to use the internal power supply once again?
1 ACCEPTED SOLUTION
RPS 2300 and 3750
Eric,
BAd news no there is no way to revert back to internal PSU without reloading.
Ref:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7148/ps7130/redundant_power_system_2300_qa.pdf
Can a device revert back to its own power supply without rebooting?
A. A Cisco Catalyst E and 2960-S Series switches are capable of reverting back to their own
power supply without rebooting. All other devices might reboot when reverting back to their
own power supplies.
Inayath
*********Plz rate if this info is helpfull and mark the thread as answerd if solved*************
1 REPLY
RPS 2300 and 3750
Eric,
Ref:
own power supplies.
Inayath
120
