RSP2300 - error or not
hi all,
i got several rps2300 on which are one or two 3750e switches are connected. because i had an error message from one of the switches i explored all with "show env rps". now i got several outputs with which i am barely satisfied. i attached three files with the output. on rps1 and rps2 all leds glow green correctly. on rps3 the leds for temp and fan are off.  rps1 shows a thermal error. not the switches which are connected and in the same place. on the output of rps2 the PID and Serial# is missing and on the output of rps3 the PID is missing. the DCOut state of all switches says ok. so is this just a display error and are the rsps will back up or are they broken for some reason ?
Nachricht geändert durch rjust1965
284
