05-31-2007 07:09 AM - edited 03-05-2019 04:25 PM
we have some Cisco switches in IBM Bladecenters:
CIGESM Software (CIGESM-I6Q4L2-M), Version 12.1(22)EA9.
They are connected to 6513 SUP720.
I'm starting the following monitoring session on 6513:
monitor session 1 source remote vlan 500
monitor session 1 destination interface Gi13/35
and on the blade's switche:
monitor session 1 source gig0/3
monitor session 1 destination remote vlan 500 reflector-port gig0/20
Switch's management VLAN is 352
The trunk config on blade switch looks like:
Port Vlans allowed on trunk
Gi0/1 2-351,353-499,501-4094
Gi0/2 2-351,353-499,501-4094
Gi0/3 2-351,353-499,501-4094
Gi0/4 2-351,353-499,501-4094
Gi0/5 2-351,353-499,501-4094
Gi0/6 2-351,353-499,501-4094
Gi0/7 2-351,353-499,501-4094
Gi0/8 2-351,353-499,501-4094
Gi0/9 2-351,353-499,501-4094
Gi0/10 2-351,353-499,501-4094
Gi0/11 348,900,904,908,912,916,920,924,928,932,936,940,944,948,952
Gi0/14 2-351,353-499,501-4094
Gi0/15 352
Gi0/19 600
Po1 1-497,499-4094
On the system connected to the interface Gi13/35on 6513 I can see the traffic from the bladeswitch's monitored port, but after around 5-10 minutes I can see that the traffic on interfaces Gi0/1-10 and Gi0/14 on the blade switch inreaces dramaticaly (see the picture) from 100 Kbits to 200Mbit and sometimes it leads to the "overutilisation" of interface and connected systems are loosing the network.
What is the problem? Configuration bug or IOS bug. Have anybody met such a problem?
thank you
06-01-2007 12:41 AM
How is gig0/20 on the blade switch configured ?
How is STP setup ?
BR,
Bjornarsb
06-01-2007 12:56 AM
Gig0/20 is not configured, has the defaults:
interface GigabitEthernet0/20
switchport mode access
spanning-tree bpdufilter disable
spanning-tree bpduguard enable
we use MSTP:
###### MST00 vlans mapped: none
Bridge address 0019.56e2.c840 priority 32768 (32768 sysid 0)
Root address 000b.60f1.5640 priority 4096 (4096 sysid 0)
port Po1 path cost 0
IST master address 000b.60f1.5640 priority 4096 (4096 sysid 0)
path cost 15000 rem hops 18
Operational hello time 2, forward delay 15, max age 20
Configured hello time 2, forward delay 15, max age 20, max hops 20
Interface Role Sts Cost Prio.Nbr Type
Gi0/1 Desg FWD 20000 128.1 Edge P2p
Gi0/14 Desg FWD 20000 128.14 Edge P2p
Gi0/15 Desg FWD 50000 128.15 P2p
Gi0/19 Altn BLK 20000 128.19 P2p
Po1 Root FWD 10000 128.65 P2p
###### MST01 vlans mapped: 1-497,499-599,601-4094
Bridge address 0019.56e2.c840 priority 32769 (32768 sysid 1)
Root address 000b.60f1.5640 priority 4097 (4096 sysid 1)
port Po1 cost 15000 rem hops 18
###### MST02 vlans mapped: 600
Bridge address 0019.56e2.c840 priority 32770 (32768 sysid 2)
Root address 000b.60f1.5640 priority 4098 (4096 sysid 2)
port Gi0/19 cost 25000 rem hops 18
Gi0/19 Root FWD 20000 128.19 P2p
###### MST03 vlans mapped: 498
Bridge address 0019.56e2.c840 priority 32771 (32768 sysid 3)
Root this switch for MST03
(VLAN 498 has some special purpose and routed)
06-04-2007 06:52 AM
I've found some problem in our MST configuration, but it was not related to RSPAN problem - the dedicated interfaces for VLAN498 was configured as access and not as trunk.
and the question again,
why should the RSPAN session flood the traffic over all ports on the source switch?
