10-31-2013 07:54 AM - edited 03-07-2019 04:21 PM
3560 X
Have have one switch setup for a local SPAN port (source Gi0/14 - destination Gi0/20).
It works great.
Now I have need to send copies from *another* switch to that same destination port.
I know I can do RSPAN to do that, but I have two questions.
1. Any issue with having two different SPANs going to one destination?
2. does each switch between the source switch and destination switch need any config? Or just the source switch?
Solved! Go to Solution.
10-31-2013 08:44 AM
Mark,
You need need to use a vlan between the switches to carry the span.
See this config guide for an example
Alex.
Please rate useful posts.
10-31-2013 08:44 AM
Mark,
Alex.
10-31-2013 09:05 AM
Alex,
thanks!
Reading through it I saw this:
•It can participate in only one SPAN session at a time (a destination port in one SPAN session cannot be a destination port for a second SPAN session).
The destination port is an audio recorder (Eventide VoIP Gateway).
I read the above that I can't send anything from ANOTHER port to that same port at the same time.
Yes?
If so, none of this will work. I can easily see traffic at the same time we need to record.
Plus, the source port on the RSPAN would be in a different VLAN than the destination port- it actually is routed, so info can get there but I'm a bit confused about needing a separate VLAN just for RSPAN...
Kind of looks like it won't work in this application- I have an alternative way to record the phones (audio forwarding to the native recorder rather than the VoIP gateway). But we would need to buy more lisences.
thanks for the help!
Mark
