Community Member
RSPAN source and destination question
Is it possible to use RSPAN/SPAN to monitor ports on two 3560 switches connected by a trunk in the following scenario:
Source ports on both switches
Traffic going to the same destination port on one of the switches?
If it is possible does anyone have an example config for the two switches.
1 REPLY
Hall of Fame Super Blue
Re: RSPAN source and destination question
Richard
As far as i know you cannot use the same destination port for 2 different SPAN sessions. And you cannot have an RSPAN source port on the same switch as the RSPAN destination port.
So i believe in this situation you would need 2 separate sessions and 2 different destination ports.
Jon
102
