RSPAN, SPAN and general monitoring techniques
brandon.n
I have a dilemma. I need to monitor 4 links. for inbound and outbound traffic. A hub is out of the question as traffic won't be seperated. Currently I am using a product called nTap to tap the four links back to a Cisco switch. The problem is SPAN only allows for 2 sessions. So 2 links can't be monitored. Attached is a diagram. Would RSPAN be better? Is RSPAN easier to configure? What exactly is VSPAN and when would it be best applicable?
So, create an RSPAN VLAN and make sure it goes wherever you need it.
Then, on the switch(es) you want to source from:
monitor session 1 source interface f2/2 options
monitor session 1 source interface f2/8 options
etc
monitor session 1 destination remote vlan 40
exit
show monitor
On your sniffing switch
monitor session 1 source remote vlan 40
monitor session 1 destination interface f0/4
exit
show monitor
Kevin Dorrell
Luxembourg
6 Replies 6
brandon.n
Bump.
Kevin Dorrell
Level 10
Level 10
I am sure this will be possible.
Generally, it is not one session per port source monitored. Each session can monitor several ports in the switch.
But before I give you a load of configs that you cannot use, what sort of switches are you working with: IOS or CatOS. And what model?
Kevin Dorrell
Luxembourg
Thanks Kevin... we have any switch you can name. Preferably I want to do it on a 3550 but a 3750 is okay as well. IOS version only, no CatOS.
etc
exit
show monitor
exit
show monitor
Kevin Dorrell
Luxembourg
Excellent Kevin.. I will try this. Your help is greatly appreciated :)
don't forget that on low-end switches eg. 2950, 2970 you need the mirror port to configure the RSPAN session. that ports should no be used and should not be in "disable" status.
